BX2200 Headlights
   / BX2200 Headlights #1
brinet
While investigating cheap filter housing strap solution (previous post) I noticed that if I left the engine shroud off, the headlights are VERY BRIGHT! After owning this tractor for 11+ years and being very disappointed with the brightness of the headlights, it appears that the cheap plastic cover/diffuser was actually blocking most of the light!
Tractor looks stupid without headlight cover and lights are pointed too high, but they are BRIGHT. I think a washer or two may fix the height issue, but what about the cover? Plexiglass?
   / BX2200 Headlights
So I guess I'm the only one in the dark on a BX2200?
   / BX2200 Headlights #3
I have an 03, BX2200 and never thought to check, but then again I don't use mine much at night. I will check and let you know.:confused:
   / BX2200 Headlights #4
There is an old forum around here somewhere where someone retrofitted HID lights into his BX. I put 100w off roads on my ROPs.
   / BX2200 Headlights #5
On my BX, the plastic cover is clear , you can see the bulb. It must be the clouded plastic on yours. I dont see an issue with plexiglass as long it doesnt melt :laughing:
   / BX2200 Headlights #6
My BX2200 light cover fell out and I ran over it. The replacement was right inexpensive, so don't hesitate to price one if yours is cloudy.
My loader bucket it the biggest treat to lighting I have, and without it, I am sure the lights would be quite good.
   / BX2200 Headlights #7
I installed HIDS on my old BX22...Super bright....I will look for pics since the older BX's are an easy install. New one are not..
2007 MACK CXN VISION (INOPERABLE) (A48992)
2007 MACK CXN...
1998 John Deere 4300 4WD Tractor (A49251)
1998 John Deere...
2014 WESTERN STAR 4900 TRI AXLE (A48992)
2014 WESTERN STAR...
Kubota RTV1100 4x4 Utility Vehicle (A49251)
Kubota RTV1100 4x4...
John Deere 350 Sickle Bar Mower (A49251)
John Deere 350...
2016 KENWORTH T680 TANDEM AXLE SLEEPER (A50046)
2016 KENWORTH T680...
