BX2200 front axle
   / BX2200 front axle #1
nbennett
West Virginia
Kubota BX2200
I changed the oil in my front axle yesterday. Most of oil drained from the first side that I removed the drain plug from. Upon refilling with oil, I assumed that the new oil would freely pass to the other wheel and equalize. I ran the tractor a little while around a sloping area try to get an equal amount of oil to the other wheel. Upon re-checking the oil levels,there was still over an inch of difference between the oil levels on each wheel. Will this eventually even up or do I need to try to add oil to each side evenly?
   / BX2200 front axle #2
The WSM indicates to fill from both sides and have the breather plugs removed. On the BX23 there's breather plugs on both sides, I'm not sure about the 2200.
It also indicates to run the tractor for about 10 minutes then check again.
Volfandt
   / BX2200 front axle #3
Volfandt has it right. You must remove the vent and fill from both sides.
Will
   / BX2200 front axle #4
Where are the vents located please? I may have overfilled the front axle and oil is dripping on the floor. I have just changed the pinion seal. image.jpgimage.jpg
   / BX2200 front axle #5
Where are the vents located please? I may have overfilled the front axle and oil is dripping on the floor. I have just changed the pinion seal.View attachment 412963View attachment 412964
The vents are those bolts that are on what looks like a brake housing. They are almost blocked by the tire.
You can see one in the first photo over by the tire on the right side.
I fill from both sides until the oil starts coming out of the vents. It will take a while before the oil seeps into all of the nooks and crannies so check the level again after five, or so, hours.
You'll have to find out where the oil is dripping from since the front axle is supposed to be a completely sealed system once all the plugs are secured. There is no overflow valve that I'm aware of. Hope it is not a power steering leak!
   / BX2200 front axle #6
Thanks very much for the info, I'll put it to good use.
I've already replaced the hydraulic steering hoses . I've also replaced the forward universal joint on the drive shaft to the front axle, however when I engage 4wd , there is a vibration feedback through the steering along with a clunky feel. The rear universal joint feels ok but maybe it needs replacing also. Any ideas?
   / BX2200 front axle #7
I don't have BX tractor, but the owner manual for my L5450 says that too much back and forth play in the front differential case can cause vibrations transmitted to the steering wheel. On my tractor there is an adjusting screw on the front differential carrier.
   / BX2200 front axle #8
Do you feel the vibration while driving? If so you may need to adjust the toe-in and or the axle pivot.
   / BX2200 front axle #9
Vibration occurs only in 4wd whilst on the move. I'm away from home for 3 weeks, so will investigate further when I return. Thanks for your suggestion.
   / BX2200 front axle #10
I realize this is over a year old, did you find out what was causing the vibration? I have a similar problem (driveshaft dropped out a few times) fixed that, now when in 4wd (and only in 4wd) there is a vibration that I can feel through the steering wheel, and sometimes in the whole tractor. Not really a bit shimmy, just a vibration.
Thanks!
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A52472)
2006 V.E...
2013 Ford Explorer XLT SUV (A50324)
2013 Ford Explorer...
2004 30ft S/A Scissor Pontoon Boat Trailer (A50324)
2004 30ft S/A...
2006 Komatsu PC400LC Hydraulic Excavator (A50322)
2006 Komatsu...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
