BX2200 Front axle seal replacement
   / BX2200 Front axle seal replacement #1
dannydan3
I know that there was a factory defect on the early 2200's with the front axle seals. I had mine fixed once under warranty, once again last year, and now it looks as though it is leaking again.
Is this normal? And is the seal replacement a bear? I'll be luck to scrape up the $$ for the seals, let alone take it to the dealer (preferred method).
   / BX2200 Front axle seal replacement #2
Mine has a slow leak on the vertical seal between the axle itself and the wheel unit, too slow to fix, kinda just wet. Which seal is actually leaking? What did it cost last time? My actual axle seals appear dry.. I wasn't aware that was (another) common BX problem...
- Patrick
These are the top seals on either side of the center pivot point.
   / BX2200 Front axle seal replacement #4
Mine is leaky also. I can not find a free service manual. I have the parts diagram so I guess I will use that as a reference. Mine is leaking bad.
   / BX2200 Front axle seal replacement #5
Consider the tried and true grease fix, or a slurry of grease and 90 W , makes it thicker and less likely to. Flow thru notoriously problem seals
   / BX2200 Front axle seal replacement #6
Not a bad idea, that would save a lot of work. Thanks
   / BX2200 Front axle seal replacement #7
they are all the same the seal leak after a whil
2016 Kubota SSV75 Skidloader (RIDE AND DRIVE) (A50774)
2016 Kubota SSV75...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
Kubota 48in Loader Bucket (A50322)
Kubota 48in Loader...
1998 Isuzu NPC (A50120)
1998 Isuzu NPC...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52576)
1999 KENWORTH W900...
