BX2200 Front axle seal replacement
   / BX2200 Front axle seal replacement #1
dannydan3
I know that there was a factory defect on the early 2200's with the front axle seals. I had mine fixed once under warranty, once again last year, and now it looks as though it is leaking again.
Is this normal? And is the seal replacement a bear? I'll be luck to scrape up the $$ for the seals, let alone take it to the dealer (preferred method).
   / BX2200 Front axle seal replacement #2
Mine has a slow leak on the vertical seal between the axle itself and the wheel unit, too slow to fix, kinda just wet. Which seal is actually leaking? What did it cost last time? My actual axle seals appear dry.. I wasn't aware that was (another) common BX problem...
- Patrick
These are the top seals on either side of the center pivot point.
   / BX2200 Front axle seal replacement #4
Mine is leaky also. I can not find a free service manual. I have the parts diagram so I guess I will use that as a reference. Mine is leaking bad.
   / BX2200 Front axle seal replacement #5
Consider the tried and true grease fix, or a slurry of grease and 90 W , makes it thicker and less likely to. Flow thru notoriously problem seals
   / BX2200 Front axle seal replacement #6
Not a bad idea, that would save a lot of work. Thanks
   / BX2200 Front axle seal replacement #7
they are all the same the seal leak after a whil
City of Clearwater (G4098) 3BPZLH0X5FF277151 Year: 2015 Make: Peterbilt Model: 320 Vehicle Type: (A51692)
City of Clearwater...
2025 Auger Skid Steer Attachment (A50322)
2025 Auger Skid...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
International 3414 Tractor w/Loader (RUNS) (A50774)
International 3414...
2006 Mastercraft S-05-1142 (A50120)
2006 Mastercraft...
1992 Peterbilt 377 Sleeper Cab (A52748)
1992 Peterbilt 377...
