BX2200 front axle pin
   / BX2200 front axle pin #1
nbennett
West Virginia
Kubota BX2200
I sheared the front axle pin but can't drive the remainder out of the shaft. My question is if the axle is held onto the rear shaft with a quick disconnect collar that will allow me to remove the axle from the tractor to more easily get the pin out? There is a collar back there that spins but will not easily slide either way.
   / BX2200 front axle pin #2
You are losing me -- can you clarify what pin you sheared? In the drive train or holding the axle onto the tractor or ?? What shaft? There is a collar back where that spins but doesn't slide easily...?
Side Note: Where in WV ? I have prop in Harrison Co (farm) and Tucker Co (cabin.) Have a BX2200 here in So MD and work on some others locally.
I'm in Mercer county. I sheared the pin that holds the u-joint on between the two shafts. After I posted this question, I got braver and hit it with a bigger hammer and the pin came out. Back in business now.
  • Good Post
Reactions: JWR
   / BX2200 front axle pin #4
Gotcha ! Glad it is resolved. My farm is in Harrison County south of Clarksburg. I'm only there once a month.
Last time I was in your county was hauling a boom cutter to the farm from South Carolina. Not down in that part of the state hardly ever.
My BX2200 is here in southern MD where I live.
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
1998 HONDA 300 FOURTRAX (A57192)
1998 HONDA 300...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
2012 FREIGHTLINER CASCADIC DBL SLEEPER ROAD TRACTO (A57192)
2012 FREIGHTLINER...
