BX2200 Fan Protection
   / BX2200 Fan Protection #1
gwdixon
Elite Member
Northern CA
Quite some time ago I indicated that I'd post my homemade BX2200 fan protector at the next hydraulic change. Instead of searching for the very old thread, here is a new one. In fact, I'm not sure this is the website. (This info will be copied/pasted to the other forum that I visit.)
The device is made out of expanded metal with the little openings oriented so that sticks are discouraged from poking through when moving forward. When you look at expanded metal you will see that one edge of the openings are higher than the other edge.
>A piece of expanded metal 36" x 14" is used. I used the smallest openings that still give a sturdy structure.
>The 14" width will fit on the frame side-to-side.
>The 12.75 width on the rear bent area is necessary to clear the frame and avoid the rear brake rods.
>The bends are different angles so that the very end section tucks up in front of the transmission and protects the filter. That way sticks that may catch and bend the protector are avoided when in reverse.
>If the MMM PTO shaft is used then the rearmost portion can be cut in half to only protect the filter.
>Another 4" or so could be added to the front of the protector but a thin section will need to be cut out to allow the steering rod through.
For securing to the tractor.
>Six nuts were welded to the inside of the frame. (Note: The nuts had a bolt in them when welded to hold the shape as well as possible. A slight warping is fine since it acts to grab the bolt like a lock nut when the protector is installed. Chasing the threads with a tap is also an option.)
>The protector was held up and where the nuts lined up the protector was marked.
>A hole was cut in the expanded metal and a washer tack welded over the hole.
>Any reasonable sized nut/bolt will do. I chose one that a 14mm socket would fit onto the head. A 14mm socket is needed for front axle service, too.
If care is taken, the hydraulic filter can be removed by bending the protector slightly (but wear gloves!)
We have orchards that are pruned. The prunings are mowed/mulched with the BX2200 and a Bush Hog. No problems yet.
   / BX2200 Fan Protection #2
I just did the dreaded replacement of all 4 hydraulic lines to steering on my BX2200 with better quality stuff, not a fun job. My fan was in good shape at 560 hours , I run mm mower a lot. I could not believe how much crud was built up on top of trans behind fan, fins were filled level. Bottom was clean as I try to pressure wash bottom side every year. FYI
Agree on the hydraulic steering lines. How about that working up under the "dashboard" for loads of fun!
Then, if you used heavier lines, getting things back together is an effort to be avoided.
REMLINGER 2300 LOT NUMBER 59 (A53084)
REMLINGER 2300 LOT...
2005 Sterling Acterra Tender Truck (A53472)
2005 Sterling...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
