bx2200 electrical problems
   / bx2200 electrical problems #1
expires2068
chatham, nj
Kubota bx23 & 22
Have a bx2200 tractor will only run if I hold the key in the start position. When I let go of key it just turns off. I have replaced the ignition switch and the stop solenoid. When I turn the key the 20 amp fuse also blows . Please help really need to get working asap. Any suggestions
   / bx2200 electrical problems #2
expires2068
I have just finished tracking down a short in my bx2200. It was where the wire bundle goes through the firewall. My issue was lights but after finding the short other wires were damaged including the wire to the solenoid.
Might start there.
   / bx2200 electrical problems #3
When you hold it in the "run" position, is the starter also turning?
What does that 20amp fuse protect?
   / bx2200 electrical problems #4
The 20 amp fuse protects the fuel shut off solenoid. The solenoid fails closed to prevent the engine from running away and not shutting down.
Sounds like you have a short in the wiring.
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2014 Chevrolet Express 2500 Cargo Van (A50323)
2014 Chevrolet...
2016 GMC Savana (A50120)
2016 GMC Savana...
2005 Mack CV713 Granite T/A Roll-Off Truck (A50323)
2005 Mack CV713...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
KUBOTA M7-132 (A53084)
