bx2200 electrical problems
   / bx2200 electrical problems #1
expires2068
chatham, nj
Kubota bx23 & 22
Have a bx2200 tractor will only run if I hold the key in the start position. When I let go of key it just turns off. I have replaced the ignition switch and the stop solenoid. When I turn the key the 20 amp fuse also blows . Please help really need to get working asap. Any suggestions
   / bx2200 electrical problems #2
expires2068
I have just finished tracking down a short in my bx2200. It was where the wire bundle goes through the firewall. My issue was lights but after finding the short other wires were damaged including the wire to the solenoid.
Might start there.
   / bx2200 electrical problems #3
When you hold it in the "run" position, is the starter also turning?
What does that 20amp fuse protect?
   / bx2200 electrical problems #4
The 20 amp fuse protects the fuel shut off solenoid. The solenoid fails closed to prevent the engine from running away and not shutting down.
Sounds like you have a short in the wiring.
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
Wolverine Quick Attach 84" Push Blade 2 Way (A50121)
Wolverine Quick...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
1995 BEALL TRAILER FUEL TRANSPORT PUP TRAILER (A52472)
1995 BEALL TRAILER...
Polecat Swift 206R 20ft Towable Boom Lift (A50322)
Polecat Swift 206R...
