bx2200 bx22
   / bx2200 bx22 #1
oombala
central indiana
kubota bx 2200
whats the differance between the bx2200 and the bx 22? just a new model year? i have yet to see a bx 22 at the dealers. just the 2200. help im gettin close to buying
   / bx2200 bx22 #2
The basic machine is the same. The 22 has a stiffened frame in the mid and rear to accomodate the <font color=red> included </font color=red> backhoe. The front end loader is also included with a 22, and an option on the 2200.
As such, the 22 is quite a bit more money, but if you include the cost of the FEL and the price for a backhoe (using aftermarket or other models as a reference, the price is attractive. This assumes that you want/need the additional accessories.
The main reason you have yet to see a 22 is that it is a new model and in high demand and short supply. I ordered my 22 in the beginning of April, and was able to get the second of the dealer's stock preorder of 5 units. I received mine in a month. When I got mine a couple of weeks ago he told me that all of the preorders were sold and he was quoting late July delivery for any new order.
BTW, the 22 is a great all around compact. You never realize how much you can do with those implements.
paul
   / bx2200 bx22 #3
Oombala,
BX22 has a back hoe, same as the BX2200 as far as engine, mower, FEL, etc, the frame has been beefed up to take the hoe,. The price range I have seen on TBN is $16,000-17,000 depending on what extras you get.
BX2200 has no back hoe
If you need a back hoe and can justify the extra $$$
well then go for it.... Just a few $$ more per month!
Looking is half the fun!
Tom
   / bx2200 bx22 #4
I got some brochures a month ago from the Kubota dealer and have a brochure for a B21 TLB. I've been wondering if the BX22 and BX2200 were being interchangeably referrenced also.
So does the BX22 replace the BX21? How does this tractor compare to the B2710/B2910 if one wants a FEL and BH?
   / bx2200 bx22 #5
Pardon my ignorance - but if you get a BX22 do you give up the 3PH? Essentially is it a small backhoe? - but can no longer use a MMM or any 3PH attachments?
Would love the backhoe - but hate to give up mowing, grading, tilling, etc.
   / bx2200 bx22 #6
The BX22 is identical to the BX2200 except it has a subframe for the mounting of the backhoe. The loader frame is slightly different because it ties into the backhoe subframe and it has rear hydraulics. The MMM and the 3-pont hitch are the same.
   / bx2200 bx22 #7
To add to jrlichina's comments, the MMM and 3PT are the same, but you must remove all of the 3PT links and arms, except for the upper main lift arms, to install the BH. This makes it a bit more of a job if you are going from the BH to a 3PT attachment. Also with the BH mounted, the 3PT lift arms, which also drive the MMM lift, will only lower slightly more than half way. At that point they hit the floor pan of the BH. This means that you can not mow with the BH attached, if you were so inclined. The good news is that the BH comes off and goes on in about 5 minutes each, so the switch is an easy one. As you might expect, the BH and FEL are fully functional with the MMM mounted.
paul
2026 Quality steel dump truck (A56859)
2026 Quality steel...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52709)
(INOP) 2019 KUBOTA...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A56857)
2025 Kivel Fork...
2007 Ammbusher DL66 Hydraulic 66in Brush Cutter Skid Steer Attachment (A55973)
2007 Ammbusher...
GRAIN BIN - APPROX. 14' ACROSS (A52708)
GRAIN BIN -...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
