diesel85
Veteran Member
Well, after 18 years, one of the steering hoses finally popped a leak... it's not the ones that go to the steering rack itself, it's the ones that go from the pump to to the hydraulic unit to assist with the steering.
I noticed it the other day when I parked it after mowing.
Ordered a new set of hoses and tube sleeve from Messick's and it will be here tomorrow.
Worked out good, because I was planning on changing the oil, fuel filters, hydraulic oil, coolant, and performing a valve clearance check this weekend anyhow.
Today I wound up taking like half the tractor apart, and I did the oil change, and fuel filters. Tomorrow is going to be the rest of the work.
The leak is likely the high pressure side. Not sure, and don't care because I'm replacing both hoses and tube sleeve because it's gross.
Got it marked with star. Hard to see in the pictures how wet it is, but it's soaked, and half the frame is covered in hydraulic oil.
When I get done, I'm going to give it a good bath with some Super Clean...
