BX2200 blinkers stuk on
   / BX2200 blinkers stuk on #1
bonz155
Maine, New York
Kubota BX2200
I have a 2002 BX2200. When the key is in the on position, The blinkers are blinking even though the blinker switch and the hazard switch are in the off position. Does anyone have suggestion as to where to start to look for a solution?
   / BX2200 blinkers stuk on #2
i'd say the switch is stuck internally. At least thats where I'd look first. Try unplugging either the power or load side (lights) from the switch and see if they go off. If so the switch is bad.
FORD 8630 TRACTOR (A60430)
FORD 8630 TRACTOR...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59905)
2019 INTERNATIONAL...
2016 Ford F-550 Altec AT233P 35ft Bucket Truck (A59230)
2016 Ford F-550...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
