Ballast BX2200 BALLAST
   / BX2200 BALLAST #1
TomPh
Kentucky
BX 2200
For those of you who have experience with liquid ballast, I need to know how much fluid it takes to fill a 26x12.00-12 turf tire 75% full.
Thanks in advance for your help.
TomPh
   / BX2200 BALLAST #2
TomPh,
When I asked this question Glenmac was kind enought to look it up in the Goodyear Ag book. Here's the thread... http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=owning&Number=74045&page=&view=&sb=&vc=1#Post74045 It was stated that 10 gals each tire would fill to 75% w/o additive. I plan to use wiper fluid but haven't gotten to it yet. I can report back when I do if you're interested. I'd also thought about using RV antifreeze which is twice as much, protects to colder temps., isn't flamable, and isn't toxic but haven't heard anyone trying it. I'd like to use the Arco foam fill but they never replied to me. The beet juice sounds like a good option but didn't find any dealers in the area.
Good luck,
Michael
   / BX2200 BALLAST #3
Wiper fluid is somewhat light, no? I guess it's better than nothing though. How do you intend to get it through the valve stem into the tire?
   / BX2200 BALLAST #4
you could check at auto repair shops, with the epa what it is, they now have to catch all the used antifreeze they drain, i found a shop that had over a hundred gallons of the stuff they were glad to let me take off their hands, i took one drum and have about half of it left. it's freeeeeeeee
   / BX2200 BALLAST #5
Milkman,
That is a great idea, I'll have to check into it. Arco just got back to me as well so I'll have to see what Superflex costs.
Thanks,
Michael
   / BX2200 BALLAST #6
JimMorrissey,
Not sure of the weight off hand but could check tonight and let you know if you want. As for filling I got a fluid fill adaptor at the local Farm & Fleet for $8. Just need to attach my drill pump and go. Dealer said they break the bead and pour in or suggested I could attach the hose, squeeze the tire and let it suck it up.
Just a couple of thoughts,
Michael
   / BX2200 BALLAST #7
Well I checked the weight on the wiper fluid and it is about 8lbs per gallon. Figure 10 gallons per rear wheel is 80lbs each. On the other hand Arnco finally got back to me stating an email mixup and put me in contact with some dealers. The first called back saying it would be 140lbs to 150lbs of their SuperFlex per tire. They quoted $1.25 per pound and said it wouldn't be more than $188 per tire and I'd have to bring them in and leave them for a few days. The other hasn't gotten back to me yet.
FWIW,
Michael
   / BX2200 BALLAST #8
<font color=blue>...Figure 10 gallons per rear wheel is 80lbs each...it would be 140lbs to 150lbs of their SuperFlex per tire. They quoted $1.25 per pound and said it wouldn't be more than $188 per tire ....</font color=blue>
Michael,
For about 79 cents per gallon of windshield washer fluid or using your figures of 10 gallons per tire...$7.90 per tire vs. $188. per tire... /w3tcompact/icons/blush.gif {that's still an extra 160 lbs. in the rear...for under $16., nothing to sneeze at...}
If you had a larger compact tractor and bigger capacity loader, I would consider "investing" more weight in the tires... but certainly not $388 worth.... that would make a nice dent in another rear implement you could use and still have ballast.../w3tcompact/icons/crazy.gif
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52709)
KNOW BEFORE YOU...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
