BX2200 and Woods M5 Daisey Cutter
   / BX2200 and Woods M5 Daisey Cutter #1
terpdog
Marriottsville, Maryland
Kubota BX 2200
Someone at work is selling and I was was wondering if the BX2200
could handle it. I've got about 4 acres I could use it on as well as some path clearing. It's 5 foot cat 1 w/ 540 RPM PTO.
Used they want 300 and it's has new shaft bearing seals.
I'm kinda new to tractoring and the BX2200 so any help would
be great.
Thanks
Chris
   / BX2200 and Woods M5 Daisey Cutter #2
I own a 2200 but use a mmm, however, the price for the mower seems good and the rpm at the rear pto is correct. The 2200 is a cat 1 so that it should mate up to the tractor. The 3ph will lift in excess of 1000 pounds, I think, so you should be able to lift the mower for turning.
Maybe someone else would comment on the mower itself.....
Thanks a bunch, the owner doesn't know much about it, ie. weight of the cutter and I know that the BX had some issues with some implements. I went to woodsonline but didn't see an M5 if anyone
know that would be great :)
Chris
   / BX2200 and Woods M5 Daisey Cutter #4
I have a Woods M5 DIXIE cutter and it would be to much for a BX2200. It is to heavy for it. I run mine on a 33 horse tractor and wouldn't want it only anything much smaller.
Thanks, my first thought was that it may be but wasn't sure.
Chris
TPM 16 Mini Excavator (A49251)
TPM 16 Mini...
Lot of 4 Unused ST205/75R15 Tires (A49346)
Lot of 4 Unused...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A47371)
2011 Autocar ACX64...
Galvanized Pipe (A49251)
Galvanized Pipe...
2018 Ford F-550 4x4 Summit 4416 Crane Mechanics Truck (A48081)
2018 Ford F-550...
25ft Extra Heavy Duty Booster Cable (A46684)
25ft Extra Heavy...
