BX2200 and 72" finish deck
   / BX2200 and 72" finish deck #1
gutterman
bx2200
BX2200 and 72\" finish deck
I was wondering if I could use a 72" finish deck on the back of my BX2200. I have a lot of grass to cut (10 acres) and every little bit helps vs the 60" MMM. The grass would be cut regularly so would not be that tall. I know of one I could borrow to try out before buying. I know it goes against factory reccomendations, but I am sure they build a safety margin into this. Any thoughts?
   / BX2200 and 72" finish deck #2
Re: BX2200 and 72\" finish deck
I think you have enough rear PTO hp, but the major question is:
is it flat??
and secondly, how smooth (lawn or field)??
if you have to go up/down hills, I wouldn't do it- the weight of that implement on the rear is very capable of pushing the tractor around.
Most of it is flat and smooth. About two acres is flat and very bumpy.
   / BX2200 and 72" finish deck #4
I guess it might be ok . BUT i think you are pushing it. 10 acres cut often is a lot to ask. what kind of grass? hills? weather? would be helpful if u filled in your profile a bit.
   / BX2200 and 72" finish deck #5
Gutterman, I had used a Woods 72" RFM on the back of my 23hp Cub 7234 with no problems except I had to be extra careful going down a steep slope when the grass was wet. It would push the tractor down the hill /forums/images/graemlins/shocked.gif if I was going too fast and then locked up my turf tires trying to stop or slow down. I still have the Woods mower and will probably try sell it. /forums/images/graemlins/cool.gif
   / BX2200 and 72" finish deck #6
What about towing one of those trailer mowers they have for behind ATV's along with the MMM? That would give you an additional 60 inches instead of 12 inches for about the same money.
2014 John Deere 700K LGP Dozer (RIDE AND DRIVE) (A50774)
2014 John Deere...
2020 Ford F-150 XL (A50120)
2020 Ford F-150 XL...
NORTHERN 3P-100 AG MIST SPRAYER (A51243)
NORTHERN 3P-100 AG...
20" Sea Container (A47384)
20" Sea Container...
New Holland 273 Hayliner Square Baler (A50515)
New Holland 273...
John Deere 1020 Tractor (RUNS) (A50774)
John Deere 1020...
