bx2200 air filter strap broke (again)
   / bx2200 air filter strap broke (again) #1
upgw
SE PA
2001 Kubota BX2200, 2011 Hustler Super Z 31 Kawi
I already have the redesigned part, I was wondering if there is another redesign to beef this up for if it's just going to keep breaking every 200 hours.. ?
Thanks,
- Patrick
   / bx2200 air filter strap broke (again) #2
I have broken 3 of them the last one over 100 hours ago I looked at it and don't see how it hurts anything to just let the plastic parts move around I am going to just leave mine broke. I cant see any damage to plastic housing from leaving it broke
   / bx2200 air filter strap broke (again) #3
Me to
   / bx2200 air filter strap broke (again) #4
When mine broke, I replaced it with a large plastic tie wrap. You can buy them at Home Depot, Lowes or maybe your local hardware store.
   / bx2200 air filter strap broke (again) #5
Ditto here. Mine broke last year and after hearing the price I would be paying for the replacement part that seemed to be not much of an improvement over the original I just grabbed an extra large nylon tie wrap and secured the filter, it will probably last longer than anything else.
The strap is available separately from the mount, it was only $8. About 20 minutes to install... guess I'll stock up or try the plastic-tie approach.
   / bx2200 air filter strap broke (again) #7
Don't think mine is broken yet--guess I'll add a zip tie next time I'm under the hood!
ron
   / bx2200 air filter strap broke (again) #8
My dealer made some sort of modification to the mounting point where the strap attaches to the engine in addition to installing the redesigned strap but I'm not sure what. So far so good though.
   / bx2200 air filter strap broke (again) #9
When mine broke I told my dealer when I was in there getting some new mower blades and he just handed me a new one and said they all break.
Tie wrap is a good Idea.
   / bx2200 air filter strap broke (again) #10
Tie wrap is OK but the plastic will get brittle pretty quick. My son took a piece of fire hose, about 2" wide when flat, cut a piece to length, drilled mounting holes and used fender washers and bolted it back in place. Has worked fine, gives when it needs to. That was 2 years ago and still going strong.
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
Red ZTR Mower (A50121)
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
Cub Cadet 7254 Compact Tractor (RUNS) (A50774)
Cub Cadet 7254...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
