BX22 will not start
   / BX22 will not start #1
Tdog
Platinum Member
SE Louisiana
BX22
I have exactly 48 hours on my BX22 & have it scheduled to go in for it's 50 hour ordeal next Tuesday - - I took off this afternoon to get in another couple of hours mowing [the pasure really needs it] & the bloomin' thing would not start. It acts like it does when you try to start it when you are not in neutral. Near as I can tell, I have plenty of battery. The PTO is not engaged.
Any other thoughts? Guess I'll let the dealer figure it out when he picks it up, but I sure did want to use it a little now.
   / BX22 will not start #2
Does you're have the kill plunger? I've forgotten to push that back in before. The other thing that comes to mind is a safety lockout switch (clutch would be a first guess) that has come disconnected or got bumped out of adjustment.
'Least your dealer is showing up soon - thought I'd throw out an idea or two to try and get you going tonight...
   / BX22 will not start #3
I had the same problem and found out that the neutral switch came loose. It is under the right side fender. You can push it in with a screwdriver and try to start the machine. Hope this helps.
Thanks pemad.
I called the service manager yesterday & he said it was unusal, but it could be the idiot switch that keeps it from starting unless you are in neutral was bad or unplugged. I got a chance to check this morning & found it was indeed unplugged. However, there's no way I could get my hand or tools in there to reconnect, just bruised knuckles.
I finally solved it by alligator clipping together the ends of the wire that was unnplugged - - it started like a charm. Since it is going in for r & r on Tuesday, I'll let the dealer worry about plugging it back in.
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
WB Mower (A50120)
WB Mower (A50120)
2013 VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A52472)
2013 VERMEER...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
