BX22 vs B7500
   / BX22 vs B7500 #11
YGuy-You will be thrilled with the B7500. I use mine on 6 acres to mow and do odd jobs and she does a great job.
Have Fun, Richard
   / BX22 vs B7500 #12
I'm pleased with the B7500. Here is a photo of a project I just finished, the brush on the right side of the lane was within 3 feet of the blacktop before I started. Tools used included a stihl brush cutter, chainsaw and B7500 with landpride 48 inch brush hog.
   / BX22 vs B7500 #13
I just went through the same selection process . I bought the B7500 and am glad I did. It fills my needs perfect. The best choice I made was getting a backhoe right in the beginning. There are sooooo many uses for the BH. The more experience I get with it the longer the project list is getting. For my uses, I think the additional clearance on the 7500 v BX is significant and should be considered.
   / BX22 vs B7500
Just went through the same process. bought a BX22 two weeks ago and love it. The thing is a worker. I have about 4 acres to mow so the main reason I went with the BX was the better mower and the frame mounted backhoe. The B7500 is a good machine and i'm sure i'd be happy with it also.
   / BX22 vs B7500 #15
1st day on website, fantasic, just started looking at tractors today. like BX2200, but the board is giving me a lot of things to sort thru, mainly figuring out abbreviations and if a BX22 is the same as a BX2200. /forums/images/graemlins/smile.gif
   / BX22 vs B7500 #16
WELCOME!
The BX22 is the same tractor with an added subframe (about 200lbs more weight for total of 1520lbs), backhoe and loader. It comes as a packaged TLB (tractor, loader, backhoe), then you can add any of the other BX implements. The BX2200 will use the same implements and can be fitted with the same loader, but you cannot add a backhoe to it.
Terry
Bron V75-3 Pull-Behind Hydraulic Vibratory Utility Plow (A49461)
Bron V75-3...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A51039)
3-Point Hitch Root...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A50854)
2014 FORREST RIVER...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2011 TROXELL...
