BX22 Tie Rod Play
   / BX22 Tie Rod Play #1
Snappy BX
Upstate NY
BX22 (sold) B2920
I seem to have a major issue.
The tapered hole on the outer gear case that the outer tie rod bolts thru is worn and elongated causing excessive play. has anyone seen this issue and is there a more economical way to repair this without replacing both outer gear cases ?
   / BX22 Tie Rod Play #2
Best suggestion, without replacing the outer gear cases is to find a competent welder, and have them fill the holes in with a welder. Then drill new ones. It will at least get you by. Not sure how it would hold up over time.
   / BX22 Tie Rod Play
Thanks Diesel, welding is the easy part, (have mig, tig, and master welders to help) the tapered hole for the tie rod seems tougher. not sure if I have one for the Bridgeport.
   / BX22 Tie Rod Play
Quick update on the repair, total investment $26.00.
Just need to shorten the bolts, wanted a shoulder through the inner gear case. will see how it holds up.
Thanks for the help and advice.
   / BX22 Tie Rod Play #5
No problem. Glad to see it worked out.
Rear Tine Garden Tiller (A51573)
Rear Tine Garden...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53472)
2021 John Deere...
UNUSED AGT 3000 PSI HOT WATER PRESSURE (A51248)
UNUSED AGT 3000...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
2018 John Deere R4038 Sprayer (A53342)
2018 John Deere...
