BX22 Propeller Shaft CV Joints
   / BX22 Propeller Shaft CV Joints #1
ehenry
Canton, ms
Kubota BX22 that was left to me by a dear friend. B7300 w/MMM
I have the shaft out of my tractor to replace the HST fan, CV boots and both joints. In looking at the parts diagram of the CV joint, it shows O-ring dampeners under each ball in the joint. The joints on this tractor are the original joints with 1300+ hours of run time and I have no clue how long they've been running with no boots. When I removed one of the joints from the shaft, I cant find any O-rings under the balls or where they might go other than they just lay in the cup that the ball goes in. I guess its possible that over time with dirt and grime the O-rings got chewed up. Can anyone that's replaced one of these joints on their BX share a little wisdom?
   / BX22 Propeller Shaft CV Joints #2
I can't find the thread, but I believe techman has done this.
Stopped by local Kubota dealer to see if parts had come in.....they had not but I did talk to one of their mechanics about the o-rings and he couldn't give me an answer cause he had never done one. He looked up the same drawing I did and said it sure looks like all the o-ring does is sit in the cup under the ball. I'm still hoping someone that's done this will chime in to say for sure.
   / BX22 Propeller Shaft CV Joints #5
Based on nothing but pure ignorance: any chance the o-rings are just to retain the balls during assembly? Can't get a mental picture of it - just wondering...
Z.
BX22 and BX24 propeller shaft CV joints are showing the exact same parts numbers.
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
Sims Snow Board (A51573)
Sims Snow Board...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
20 Yard Rolloff Container (A51573)
20 Yard Rolloff...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
