BX22 Owners Help
/ BX22 Owners Help #1
KWentling
Rozet, Wyoming
Kubota BX22, Kubota ZD21, Kubota M7060
I'm having problems with air in the bucket tilt cylinder on my 22. Dealer says its normal. Could you try this for me? With the tractor at about 1/3 throttle, curl the bucket up, then back down and hold till the air is purged, then back up and then down. Grab the lip of the bucket and see if you can raise it, and if so, how much. Do this both using the regular dump position and the quick dump position. On mine I'll have anywhere from 2" to 6" of free travel in the cylinder itself. Doesn't matter which dump position I use. Might be a little less using the quick dump posion. It is less of a problem at higher throttle positions but is still present to some degree. So is this "normal"?
Kim
/ BX22 Owners Help #2
I will check mine in the morning, however in exchange, I need you to check something on your BX22. Is it difficult to disconnect and reconnect the red coupling on the loader. I am having a hard time taking it apart and even worse time trying to get it back together. I think that this coupling is what is giving my machine hydraulic problems.... thanks The Junkman
/ BX22 Owners Help #3
Junkman
On my BX 22 the hoses can be difficult, but I have found that
after I shut the engine down I need to work the loader lever in all directions as well as lower the mower lift lever up and down to relieve all pressure on the hydraulic system. When this has been done the hoses come on and off without any undue pressure.
Hope this helps.
Greg
/ BX22 Owners Help #4
Junkman ----I also do the release hyd pressure but yes some of the couplings (the collars) are a pain to latch. It seems like I have to push or pull on the collar to make sure they lock in place. They do not lside on there own.
It is even worse under the loader control box!
/ BX22 Owners Help #5
GSXR1100...... it isn't the collars that I am having trouble with, but rather putting it back together. It seems that there is pressure in the line that is the problem. I have to push like heck to join them. thanks... Junkman
/ BX22 Owners Help #6
I also own a bx22 I have heard that temerature change can affect this. Like if you remove your loader when it is cool and you try to reinstall it when it is hot or warm the hydrolic fluid in the loader can expand and increase the pressure. I personaly have not had a problem reconnecting the quick disconnects to the loader. I have only removed it a couple of times. David.
/ BX22 Owners Help #7
Junkman- To you move the loader control in all directions? If so does the loader work ok when all hyd lines on? Just asking to see if the valve is sticking (inside).
/ BX22 Owners Help #8
Sir:
You have a regenerative loader control valve just like I have on my larger 5030 HSTC.
When you dump your bucket and push the joystick over to the far right with the engine at slower rpm, the cylinders empty themselves of fluid faster than the pump can refill them. That causes the "limp" effect.
I have the same scenario.
I don't particularly like the feature. Kubota told me the 4 way valve is designed for angling front mounted attachments like a power broom. Go figure.
/ BX22 Owners Help #9
the problem started after dumping some rocks..... the bucket wouldn't lift very quickly and the rapid dump wouldn't work at all. The curl was moving properly. All the lines were properly connected and I pulled on each of them to make sure that they weren't partially disconnected. I finally disconnected each of them and reconnected them one at a time. The only one that I had trouble with getting disconnected or reconnected was the red one. It was difficult to pull back the collar and difficult to pull it apart and putting it back together had the same problems.... pushing it into the female half and then getting the collar to seat. After putting everything back together, the bucket worked properly again. It hasn't failed since and that is in the past 3 work hours. When this problem started, the backhoe wouldn't work at all. I also moved the joy stick around to all positions to relieve any pressure in the system. Has me baffled as to what caused the system failure.. The dealer has no idea ether.... thanks The Junkman
/ BX22 Owners Help #10
I tried this on my BX 22 yesterday and found that the bucket was rock solid and all that I could get out of it was about 1/2" play..... Junkman
/ BX22 Owners Help
Junkman: I tried the red quick coupler after relaxing all motions and it was very easy comming apart and back together. It sounds like one of them must not have been seated good and was blocking the flow. I've also had some difficulty making connections due to temperature differences and expanded fluid.(not yet with the BX) If you can't get them together, you can relieve the pressure in the line by smacking the male end on something to depress the check and release some oil. Just becareful doing this because the oil will have some pressure behind it!
Thanks for trying the dump for me. If it was only the quick dump that put air into the system, I'd just defeat it again, but doing that didn't help because it does it in the regular dump also. Now that the quick couplers have been hashed out, could we get back to my problem in the first post? Could I get some of you other guys to try this for me? I would greatly appreciate it. I'd like to get some other results to show the dealer that this isn't "normal".
Kim
/ BX22 Owners Help
Daryl: I know abou the regenerative quick dump position on the valve. I disabled it on my BX for a time by cutting a piece of pvc pipe the correct length and slipping it over the spool so the lever would stop before it got to that position. That didn't help my problem because it does it in the regular dump position also. Sometimes I think it may be worse even.
Kim
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
2018 Kia Soul SUV (A61574)
2018 Kia Soul SUV...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
ABI 80-ASRT-074 Command Seeder Tractor Attachment (A61572)
ABI 80-ASRT-074...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
