bx22 not starting
/ bx22 not starting #1
crace2
My BX22 will not start as if it is not in neutral, but it is.
Is there another switch ?
/ bx22 not starting
Mike, yes the PTO is off, and have power to lights.
/ bx22 not starting #4
Some of the BX's have a seat safety switch (where you get off the seat in gear, the motor dies). Not all have it.
Might be another place to look.
ron
/ bx22 not starting #5
Did you jump that neutral switch?
I've had mine act up once, sprayed oil & moved the lever a few times & voila...it ran.
Bird
/ bx22 not starting #6
sounds like one of your safety switches is either not working right or is unplugged. They aren't that hard to find.
Could be ign switch, starter solenoid, or wires in between.
/ bx22 not starting #7
</font><font color="blue" class="small">( My BX22 will not start as if it is not in neutral, but it is.
Is there another switch ? )</font>
The only problem I have had with my BX23 was the neutral switch. I shortwired it just to make sure it was "the one" causing problems. Started right up afterwards. I went straight for this solution as I actually heard it break when moving the lever.
You might try to measure power to and from it with ignition on / when key is turned to a starting position. If only power in one cable, then problem found. If no power, then problem before this switch. Think it's the pto switch before the neutral switch?
/ bx22 not starting
Thanks to all have responded. I jumped the neutral safety
switch wire and away it went. Chris
/ bx22 not starting #9
Congrats.
And thanks for posting the solution..............
ron
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
2006 JOHN DEERE 310G BACKHOE (A65053)
2006 JOHN DEERE...
Wooden Swing (A64557)
2025 Wolverine MSG-11-44W 44in Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A64553)
2025 Wolverine...
