BX22 Front hub seal leaking..
   / BX22 Front hub seal leaking.. #1
jnjpream
Berthoud CO
BX22
Has anybody had an issue where oil seeps through the front hub seal where it pivots (vertical axis) ? The dealer replace the seal three times and tried silicone around the seal seating surface but nothing seemed to fix it.
The only thing I can think of is that the prev owner overloaded the front end and bent the casting some how.. But I don't want to spend $200 until I've checked around some.
Any ideas?
Thanks.
Jeff
   / BX22 Front hub seal leaking.. #2
I read on TBN that Kubota switched to a vented dipstick filler to prevent pressure forcing grease through the seals.
2019 Ford F-350 4x4 Ext. Cab Palfinger PSC 3216 4,000lb 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
2004 Mercedes Benz E-Class Sedan (A50324)
2004 Mercedes Benz...
2025 25ft 1 Gauge 800 Amp Booster Cables (A50323)
2025 25ft 1 Gauge...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2007 FONTAINE TRAILER CO. 48X102 SPREAD AXLE STEPDECK (A52472)
2007 FONTAINE...
