BX22 FEL Float position
/ BX22 FEL Float position #1
jeffmazz
Cumberland County PA
Kubota BX22--Wheel Horse 520H
Hi all,
When the FEL joystick is pushed into the float position is it supposed to lock in that position? If I take my hand off of the joy stick it springs back to the neutral position. Is this normal?
Thanks in advance,
Jeff
/ BX22 FEL Float position #2
yes. it is supposed to stay in the float position until you pull it back out of float. Are you pushing it far enough forward to engage it. If so, then you have an adjustment problem
Thanks for the replies guys. I put a call into the dealer and scheduled an appointment to drop her off. Dealer said it would be done same day.
Thanks again.
Jeff
/ BX22 FEL Float position #5
Looks like the dealers are up to speed on the problem.
I wonder if Kubota has a TSB for this yet.
Let us know what what they find in there.
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
2001 Sterling Single Axle Dump Truck (A62613)
2001 Sterling...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2003 Kenworth T800 Log Truck (A62679)
2003 Kenworth T800...
2016 Ford Transit 350 Service Van (A64556)
2016 Ford Transit...
