BX22 3 Point Adjusters revisited
   / BX22 3 Point Adjusters revisited #1
GaryG
San Diego
BX22
If you don't make any other changes to your BX22, this is a must. It makes your 3 point adjustments a breeze. The parts are ordered from a B2710. Detailed instructions are in another thread. I used Walt's guidance and it was not a big job to modify the parts to fit. There are a couple ways to attach the adjusters. I like this method as it does not constrict the movement of the 3 point arms. I am just amazed that Kubota did not put these on the tractor to start with.
   / BX22 3 Point Adjusters revisited #2
Yup...but I bagged the loose connections and pinned directly to the plate with the original hardware. Some folks went so far as to drill them out a little bigger and use bushings with bolts.
   / BX22 3 Point Adjusters revisited #3
Hey Gary I ordered the same parts for my tractor. I should have them in a week or so. Looks like you don't have to do a lot of modification to install them thanks for the attachment.
David
   / BX22 3 Point Adjusters revisited #4
Just ordered the parts.
Dealer said there was only (2) of the 6C070-65320 left in the
country (according to his computer). He said, /forums/images/graemlins/grin.gif and I hope I got them. Looks like alot of B series owners are making this modification. Now you see why kubota sells them without quick adjustment.
   / BX22 3 Point Adjusters revisited #5
My dealer confirmed same: 65320 on back order from Japan, ETA early July; 65333 still available.
   / BX22 3 Point Adjusters revisited #6
Hi Gary My parts are at the dealer I hope to pick them up friday or saturday David.
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2006 Toyota Highlander SUV (A50324)
2006 Toyota...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
