Oil & Fuel BX1830 pauses while mowing
/ BX1830 pauses while mowing #1
BobG116
North Central Ohio
BX1830
While mowing with my BX1830 which is 5years old and has 780 hours on it . I am mowing and then I experience a slight pause but it keeps going. I have changed the fuel filters , and even added a gas additive. I mow for approx. an hour and then a slight pause. Sometimes I can mow for 2 hours and no pause. I've checked all electrical connections and everything seems intact.
I was wondering if anyone on here has experienced this. I really appreciate reading on this site because so many of you really know whats going on. I would appreciate hearing your comments. Thanks.
/ BX1830 pauses while mowing #2
hmm two things comes to mind here. first is gas additives? do you mean diesel additives?
the other thing is I wonder if you have one of those older seats that makes you feel like you are sliding forward that makes seat safety switch keep kicking in?
/ BX1830 pauses while mowing #3
Check your seat safety switches, my BX was doing the same thing.
I used diesel additives, and I did check the seat safety switch to make sure it had full contact. Thanks for your reply.
/ BX1830 pauses while mowing #5
Don't want to beat it up...but, even if your seat switch is making good contact, your butt may slip forward and you are not realizing it. That is what they are trying to say. Use to happen to me, then new seat style. Keeps my butt in place.
/ BX1830 pauses while mowing #6
what we are trying to say is that there was a recall on seats to swap out explaining the issue you are having. Can you post a pic of the seeat, maybe one of us can tell quickly if it the right one or not.
I will take a picture tomorrow and post it. Thanks again for your help.
/ BX1830 pauses while mowing #8
If it's like my BX2350, you can reduce the spring pressure by removing one of the two spring leafs. My 135 lbs, particularly in the old style seat, couldn't keep enough down pressure!
To radioman, I've tried downloading the picture and wasn't successful. This was my first attempt in doing this and did something wrong. If you could give me some instructions on how to download the pictures I would appreciate it. Thank you, Bob
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
HAMM H12i ROLLER (A65053)
HAMM H12i ROLLER...
2023 Kubota SVL97-2 Compact Track Loader (A63689)
2023 Kubota...
Ford Golden Jubilee Tractor (A66285)
Ford Golden...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
