Tires BX1830 and BX25, wheels and tires are they the same???
   / BX1830 and BX25, wheels and tires are they the same??? #1
stuarth
Northern Ohio
Kubota BX2670
I have a chance to purchase all 4 wheels and turf tires for my BX25 from a BX1830.
The tires I am looking to purchase match up size wise except for the fronts that are 18x8.50-8 instead of 18x8.50-10. I don't have any idea if the wheels are the same or the bolt pattern will match up either. What I do know is that the ones available are from a BX1830.
Any help would be appreciated as the sale ends today 1-25-09 Sunday at 5pm.
   / BX1830 and BX25, wheels and tires are they the same??? #2
I'm sorry to say that the front 8" will not work with the BX25. I've had a chance to test this switch. The front axle has been change, bigger axle end.
Richard
   / BX1830 and BX25, wheels and tires are they the same??? #3
I don't know about the 1830 but the 1850 and 1860 have 24" rear tires while the BX24/BX25 have 26" rears.
Edit: Just checked the spec's for the 1830 and it lists the rears as 26x12x12, so at least the rears would work.
   / BX1830 and BX25, wheels and tires are they the same??? #4
Bird1968 is right. After I posted, I went out and looked at the BX24 and there was not a lot of clearance inside the front wheel. I just checked the part numbers and the front axle housings are different. My apologies, I should have done the research before I gave the erroneous info.
The info I have shows the 1830 as using the same 12 x 26 rear tires as the BX24.
Thank you all for the advise, I guess I could bid and if I win the auction use the rears and sell the fronts but with with the distance I am going to keep looking for the correct set of four. If anyone has a BX1830 they look almost new and are on eBay ending today.
   / BX1830 and BX25, wheels and tires are they the same??? #6
Have you checked with your dealer? When I was tractor shopping, a local dealer had a BX2350 that had turf tires on it. I told him I wanted R4s and he said he would get me a set of four tires and wheels for $150. I am sure this was probably his cost, but if you have a good relationship with your dealer, you might get a fair price from him.
   / BX1830 and BX25, wheels and tires are they the same??? #7
Retail for a front pair is around $104.00
Anyone want to sell me a set of turfs and wheels for a BX25? I am looking for new or even like new. I would be happy to pay $150 even $250, let me know...
Thanks,
Stu
Side Slinger Manure Spreader (A49251)
Side Slinger...
7000LB Axle (pair) (A49251)
7000LB Axle (pair)...
Fork Lift Forks (pair) (A49251)
Fork Lift Forks...
2015 INTERNATIONAL 4300 BOX TRUCK (A50046)
2015 INTERNATIONAL...
176867 (A48837)
176867 (A48837)
WANCO 6K LIGHT TOWER (A48992)
WANCO 6K LIGHT...
