BX1800 Stearing Problems?
/ BX1800 Stearing Problems? #1
steveky
Philpot, Ky
Kubota/ L3010HST, BX 1800
My stearing feels like there's lots of play, constantly having to move wheel back and forth to control tractor. Replaced the seals in the stearing cylinder a few years ago. I'm thinking it just went out completely that time. Any ideals on what might be the problem?
Thanks
/ BX1800 Stearing Problems? #2
Most likely the steering cylinder again. If the internal piston seals are blown the fluid will swap back and forth causing the problem you describe.
/ BX1800 Stearing Problems? #3
If Art Q is correct about the steering cylinder seals being bad again, be sure to check the cylinder itself to make sure the cylinder walls aren't scored and causing the seals to fail.
I had hydraulic cylinder seals replaced under warranty, and they failed again too soon. I tore it down myself and found that the cylinder walls were scored. I replaced the cylinder and the seals and it's been ok since.
Another possibility is worn tie-rod ends, but on a tractor I'm not sure that would give you "lots of play"; more like "a little play" or "no control at all" if they break.
I'm not familiar with your tractor, but if there's a u-joint between your steering wheel and the power steering unit, you might check for excessive play in that joint.
Finally, another possibility, if you're short on hydraulic fluid, you'll have lots of play and kind of erratic jerky steering.
2004 IC Corporation 3000IC School Bus (A64194)
2004 IC...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2023 TOPCAT 4IN1BCT (A67148)
2023 TOPCAT...
PALLET OF CULTIVATOR PARTS & FERTILIZER APPS. (A64278)
PALLET OF...
