Bx1800 snowblower lift cylinder seized.
   / Bx1800 snowblower lift cylinder seized. #1
toddbiss
Enfield, NH
2011 Kioti CK20hst
The cylinder on my snowblower is stuck. $359 for a new one. Is there a way to get one the same size cheaper or should I try a rebuild?
   / Bx1800 snowblower lift cylinder seized. #2
What is the size of the cylinder and length of the stroke? Is it push / pull or push / gravity return?
Says 2x5 it lifts and has down pressure. 20201211_191442.jpeg20201211_191438~2.jpeg
   / Bx1800 snowblower lift cylinder seized. #4
Without actually measuring your cylinder my best guess would be that the cylinder is 2" and the stroke is 5".
I would do a quick search for a double acting 2" hydraulic cylinder with a 5" stroke. I did a quick search and found a 2"x4" cylinder for $85 (2 bore x 4 stroke hydraulic cylinder, tie rod double acting cylinder | Magister Hydraulics).
I think the 5" stroke is going to take a bit to find but it certainly should be available.
Hope that helps
Tom
   / Bx1800 snowblower lift cylinder seized. #5
You sure its stuck? Did you try taking the top pin out and rotate the rod...
   / Bx1800 snowblower lift cylinder seized. #6
It will NOT be seized. It could be locked in position hydraulically because of problems external to the cylinder.
Why do you think it is seized?
What have you done to try and fix it.
What is the cylinder controlled by?
Has it worked on this tractor previously?
Dave M7040
Hope that helps
Tom
Thanks for your help. That helps a lot. I wasn't sure what the 2x5 meant, and didn't want to assume.
   / Bx1800 snowblower lift cylinder seized. #8
Check your hydraulic disconnects to make sure they are fully seated.
Dave M7040
So we got it freed up but it has limited stroke after it was reinstalled. Not sure if it is air locked or needs a rebuild. First winter with this tractor so not sure if had this problem on the past. The previous owner was pretty meticulous with maintenance though.
   / Bx1800 snowblower lift cylinder seized. #10
Cycle it up and down to get the air out.....
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51246)
2017 KOMATSU...
Toro Mower (A50324)
Toro Mower (A50324)
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
UNUSED JCT 84" HYD 4N1 BUCKET (A51248)
UNUSED JCT 84" HYD...
RYOBI 420V BRUSHLESS ELECTRIC 21" PUSH MOWER (A51248)
RYOBI 420V...
