Oil & Fuel BX1800 - repriming fuel system
   / BX1800 - repriming fuel system #1
mwechtal
Corning, NY
Kubota BX1800
I have a new / used BX1800, and I managed to run out of diesel with 1/2 a tank showing on the fuel gauge.
Can anyone tell me how to reprime the system? Yes, I know I need to order a manual, but I'd like to get back up and running before it gets here.
Thanks.
Mike
   / BX1800 - repriming fuel system #2
You should be able to just turn the key on for about 30 seconds to let the electric fuel pump build up pressure to the injector pump. Then start it, might take a couple of times.
Well, I started it a few times, but I probably didn't let the fuel pump run that long. I'll give that a try.
Thanks.
Mike
   / BX1800 - repriming fuel system #4
i ran my B7100 out of diesel a couple weeks ago. i used the search thread here and this fantastic board came up with the perfect suggestions.
for the B7100 i just cracked the bleeder valves at the fuel pump per the suggestions of previous threads and it cranked right up. took a 10mm wrench about about 4 minutes.
I tried searching, but didn't find anything specific to the BX1800. I guess I should try again with different search terms.
Thanks.
Mike
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
(3) BUG REFLECTORS IN BOX (A58374)
(3) BUG REFLECTORS...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
LOT: (40) 14 Oz. Tubes of Red Lithium Complex NLGI #2 Grease (A59076)
LOT: (40) 14 Oz...
