BX1800 Loader - burst a hydraulic hose
   / BX1800 Loader - burst a hydraulic hose #1
mclaire
Anybody ever burst a hose? I've searched these archives and I don't see this happening to anybody.
Newbie BX1800 owner here - bought it used with 320 hours on it a couple weeks ago. It came to me in excellent condition, no signs of any abuse at all. The prior owner certainly wasn't afraid to use it, but there are no bends, welds or any signs of abuse.
Anyway - I was digging around a stump yesterday and I was working it pretty hard. As I was moving the bucket back and forth, scraping at a root when it happened.
Was I definately overdoing it? Or was it possibly just weakened from many hours of loader work?
Mike
Mike
   / BX1800 Loader - burst a hydraulic hose #3
I did the same thing on my 5030 last weekend, i had the dealer fix it and now its slowly leaking after this weekend so i got to bring it back again.
   / BX1800 Loader - burst a hydraulic hose #4
   / BX1800 Loader - burst a hydraulic hose #5
You will not usually break a hose with the tractor hydraulic pump… It is more common to bust a line or hose when you hang the leading edge of the bucket while shoving and forcing the dump cylinder piston… there are no relief valves in that circuit when not using the loader control valve.
You can generate very high pressure forcing the piston to move inside the cylinder… Hope you follow what I am attempting to describe. KennyV.
   / BX1800 Loader - burst a hydraulic hose #6
   / BX1800 Loader - burst a hydraulic hose #7
And it could be a weak spot in the hose................
It's a part of tractorin'
ron
   / BX1800 Loader - burst a hydraulic hose #8
ron
Yes, I follow. That's exactly what I was doing, and with no relief valve I now see why it happened. I seem to do that quite a bit - using the downforce of the bucket while working the dump back and forth. So if I keep doing it I guess I can expect to burst another hose.
Is this a bad practice? Hard on any of the system? I'm not bending any metal so I figured I was OK.
Mike
Mike
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2005 Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
2005 Caterpillar...
2019 INTERNATIONAL LT625 (A52472)
2019 INTERNATIONAL...
2023 Utility Cargo Trailer (A51572)
2023 Utility Cargo...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
