BX1800 hydraulic valve, where to plumb?
   / BX1800 hydraulic valve, where to plumb? #1
Robcat
I want to add a hydraulic spool to my BX1800. Does anyone no or have pictures of where to get the pressure from, and also where to return the oil?
   / BX1800 hydraulic valve, where to plumb? #2
Are you trying to add rear remotes? Do you have the valve for an FEL already?
   / BX1800 hydraulic valve, where to plumb? #3
Kubota sells a dual spool kit for the newer BX series tractors - neat kit and very clean install and the price was reasonable. I added the kit to my old BX1860. I'd check with your dealer if there's a kit for your BX1800. It's a wholegoods item so you'd have to order it through sales and not parts. Here's a few pic's of my old BX1860 install. I think somewhere along the way, Kubota moved the hydraulic block from the left side to the right side (looking from the rear) of the tractor.
   / BX1800 hydraulic valve, where to plumb? #4
That is a very clean set-up, thanks for posting your pictures. Couple questions, if you will. How much? And, did the dealer do the install?
Thanks.
   / BX1800 hydraulic valve, where to plumb? #5
Thanks.
The kit was $320 ordered from Messicks a few years ago. I did the install, which wasn't bad if you remove the one rear tire. A little tight to swing wrenches in there, but it's doable. I didn't think that was a bad price for the valve, metal tubes, female QC's and linkages/levers. Doubt I could have saved much if anything putting a kit together myself and it sure wouldn't have looked as nice.
   / BX1800 hydraulic valve, where to plumb? #6
Thank you CHD.
Definitely a good price in the scheme of Kubota prices :thumbsup:
I would like to do a hydraulic top-link set-up, and that's just the ticket right there.
   / BX1800 hydraulic valve, where to plumb? #7
Thank you CHD.
That was the first thing I did after adding the remotes, then I added a small 3PH wood splitter. Go for it. :thumbsup: (I miss my HTL - can't put this valve on the BX25 as it interferes with the backhoe subframe :( )
There is no loader on this tractor, just the 3pth. Where would i tap in for pressure? I only want to add a single spool gresen valve i have on hand.
1263 (A50490)
1263 (A50490)
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
New/Unused CFG Industrial QK18R Mini Excavator (A51573)
New/Unused CFG...
2019 Allmand...
WB Mower (A50120)
WB Mower (A50120)
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
