Bx1800 Filled tires.
   / Bx1800 Filled tires. #1
toddbiss
Enfield, NH
2011 Kioti CK20hst
My old man just picked up an older BX. Pretty light in the rear. Anyone fill their rear turf tires? I know they are pretty small so not sure if it is worth it. Thanks for any info.
   / Bx1800 Filled tires. #2
really all depends on what you are doing with it.
A smaller tractor like that doesnt cost much to fill the tires. Give it a try to see if it helps.
   / Bx1800 Filled tires. #4
Fill em with water and experiment with fill ratio to see how you like it. You can always put in anti freeze later if you like it.
   / Bx1800 Filled tires. #5
You will find the filled tires make the unit seem less tippy. Up here in the cold country we use beet juice. If you ever get a flat that stuff won’t pollute....although the bears might like it!
   / Bx1800 Filled tires. #6
I filled my Kubota ZTR rear tires. They only took 8 gallons each IRC. 65 lbs x 2 = 130 lbs; still better than a sharp stick in the eye.
   / Bx1800 Filled tires. #7
My BX2230 has filled rear tires along with wheel weights. Hauling a full bucket of dirt, I feel comfortable with it. But I am still cautious when on side slopes. Jon
1275 (A50490)
1275 (A50490)
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2022 Ford F-250 XL...
2008 Chevrolet Suburban SUV (A51694)
2008 Chevrolet...
2014 John Deere 630FD Draper Head (A53342)
2014 John Deere...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
