Bx1800 Filled tires.
   / Bx1800 Filled tires. #1
toddbiss
Bronze Member
Enfield, NH
2011 Kioti CK20hst
My old man just picked up an older BX. Pretty light in the rear. Anyone fill their rear turf tires? I know they are pretty small so not sure if it is worth it. Thanks for any info.
   / Bx1800 Filled tires. #2
really all depends on what you are doing with it.
A smaller tractor like that doesnt cost much to fill the tires. Give it a try to see if it helps.
   / Bx1800 Filled tires. #4
Fill em with water and experiment with fill ratio to see how you like it. You can always put in anti freeze later if you like it.
   / Bx1800 Filled tires. #5
You will find the filled tires make the unit seem less tippy. Up here in the cold country we use beet juice. If you ever get a flat that stuff won’t pollute....although the bears might like it!
   / Bx1800 Filled tires. #6
I filled my Kubota ZTR rear tires. They only took 8 gallons each IRC. 65 lbs x 2 = 130 lbs; still better than a sharp stick in the eye.
   / Bx1800 Filled tires. #7
My BX2230 has filled rear tires along with wheel weights. Hauling a full bucket of dirt, I feel comfortable with it. But I am still cautious when on side slopes. Jon
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2022 KMC 5610 LOT NUMBER 212 (A53084)
2022 KMC 5610 LOT...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A52576)
2005 INTERNATIONAL...
FAKE (A52472)
FAKE (A52472)
