BX1500 vs BX2200 Length
   / BX1500 vs BX2200 Length #11
The lower lift arm pins for the BX22 could be made to work on a BX2200 but not without some modification. The configuration on how they bolt to the frame is different. You would have to cut off a piece on the frame to get them to bolt on correctly. If you look at a BX22 you'll see what I'm talking about.
   / BX1500 vs BX2200 Length #12
Hi.......
Are you asking ME to look at the BX22?? I know how it works. I think you want to tell Surfran what you are saying? /forums/images/graemlins/confused.gif
   / BX1500 vs BX2200 Length #13
That was for Surfan to look at a BX22, you obviously know what it looks like. It's easier for him to look at it rather than me type a huge description... /forums/images/graemlins/tongue.gif
   / BX1500 vs BX2200 Length #14
I can not show you pictures no digital camera. but as others have stated the bx-22 is in two pieces with enough room to get one bar off at a time, after you remove sway bracket. looking at the tractor from behind the left hand side pin is part# k2591-39080 the right side is k2591-39090. it is made this way to remove 3-pt. hitch to attach backhoe these parts may fit a bx2200 ask the dealer or go check them out yourself. the bx2200 design it not very user friendly if you want to remove those arms. I didn't even notice it was mad that way.
   / BX1500 vs BX2200 Length #15
Did not want to post this hear but you had no email adress. parts #10, and 20.
  • 260927-Pages from bx22.pdf
   / BX1500 vs BX2200 Length #16
Thanks, that is totally different than mine.
Dwayne, sorry didn't mean to hijack your post.
No problem my question was already answered.
   / BX1500 vs BX2200 Length #18
Ok so much for not having to type in a huge description...well not too long. On the BX22 from the PDF you can see that the lower BH weldment hook provides the locating and bolting function which is found on the OUTSIDE of the the fender bracket(item 050 & 060). On the BX2200 the locating weldment is on the INSIDE of the fender bracket. The BX22 lower pins need to mount flush to the inside of the fender bracket. You would have to cut this piece off and weld it on the outside or make a new piece. So depending on your fabrication skills it can be done relatively easy.
2006 CATERPILLAR D604S GENERATOR (A48992)
2006 CATERPILLAR...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
TOYOTA FGU35 FORKLIFT (A48992)
TOYOTA FGU35...
Crane Carrier Co Side Loader Garbage Truck (A48081)
Crane Carrier Co...
2025 Kivel 48in Forks and Frame Tractor Loader Attachment (A49346)
2025 Kivel 48in...
(2) 24FT BOLSTERS (A48992)
(2) 24FT BOLSTERS...
