BX1500 Tiller and Mower Both Mounted
   / BX1500 Tiller and Mower Both Mounted
I don't think you will need to disconnect the links. You can lift the 3 point anytime and the mower deck should remain down. There is nothing forcing the 3 point down other than gravity and weight. Done that more than once in a pinch or by being stupid.
Mmmm not a description of my situation, but I wish it were. Visited Kubota dealer this morning on another subject and checked out new ones for fun.
Well Eagle1 in response to your emphatic statements I did try something I'd never tried b4 on the BX1500.
I pulled the lift control LEVER all the way back to lift both mower and tiller, and turned the lift control KNOB under my right hand to lock everything. I think I turned CCW to lock it, not sure now. Anyway at that point tiller and mower were locked inthe highest level.
(I don't think the "TOP" position on the mower height control has much to do with these things, I may be wrong.
I still thought they were completelty connected. The only control I had to use was the lift lever, so I let it down a slight bit. By gosh and by darn, the tiller stayed sort of all the way up but the mower dropped more than I thought it would. I don't know if it's enough for mowing or not but I will certainly try.
Evidently as you said there is some individual "dropping" available for the mower.
Mike
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
STAINLESS STEEL WARMING STATION ON WHEELS (A58374)
STAINLESS STEEL...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58018)
2018 FREIGHTLINER...
BUNDLE OF 6" X 12" BUILDING PURLIN (A54757)
BUNDLE OF 6" X 12"...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
2017 Kawasaki Mule KAF620S 4x4 Utility Cart (A55973)
2017 Kawasaki Mule...
