bx1500 questions
/ bx1500 questions #1
chucko
Polk Co , Fl
bx1800
I have been looking at these things to mainly mow about 1ac here in fla. It has been a long fight with the wife about the cost of "that thing" to mow but I know you guys can't help me with that. Anyhow the dealer I would buy from is out of them now and I showed one to the wife at another dear and have some questions.
To the right of the seat there seems to be a slot for a lever that is not there. What is it for?
When I would raise the 3pt it worked both the mm deck and the three point hitch at the back. I could see you could adjust the deck all the way up so you don't have to remove it to work a box blade. But is there a way to keep the box blade (or whatever) up and lower the deck
Will they run a 54 inch deck ok. Dealers around here keep try to get me to get a 48" deck but I think it is because it is what they order
Also how well do the baggers on them work. Sales guys keep trying to talk me out of a bagger.
/ bx1500 questions #2
</font><font color="blue" class="small">( I have been looking at these things to mainly mow about 1ac here in fla. )</font>
The BX series are great mowers!
</font><font color="blue" class="small">( To the right of the seat there seems to be a slot for a lever that is not there. What is it for?)</font>
Nothing. I'm not aware of any option that mounts in there on this series.
</font><font color="blue" class="small">( When I would raise the 3pt it worked both the mm deck and the three point hitch at the back. I could see you could adjust the deck all the way up so you don't have to remove it to work a box blade. But is there a way to keep the box blade (or whatever) up and lower the deck)</font>
Nope, sorry. As you mentioned, you can lock the mowing deck up and work the 3PH but not the other way around. You would probably want to remove the deck to do serious box blading anyway for better ground clearance and less chance of getting hung up on the deck when going over piles of stuff.
</font><font color="blue" class="small">( Will they run a 54 inch deck ok. Dealers around here keep try to get me to get a 48" deck but I think it is because it is what they order
Also how well do the baggers on them work. Sales guys keep trying to talk me out of a bagger. )</font>
Others can answer these questions better than I can.
Good luck and ENJOY! /forums/images/graemlins/grin.gif
/ bx1500 questions #3
Can't directly answer your questions about your BX, as I'm still looking at getting a BX1500/1800, JD4010 or NH TZ18D. Can comment on the bush hog size regarding Hp.
Folks have used 12 hp Gravelys to run 50" mowing decks. Their comments are they are fine for this as long as the grass isn't way high.
So, I'd think the BX1500 would power the 54", but my cabinet maker, who just bought a BX2200, commented that the weight of the thing back there could be a factor to consider. There are many times where you may be backing the bush hog, partly raised into a brush pile to do away with it. If you're on a hill when doing this, the extra weight of a big hog could maybe give you some stability problems.
Lets here from any users. I'd really like to have a 60" because this is what I get in round trips with my 30" Gravely on my trails. Weight-wise and all, doing trails with a 60" would be fine. Would have to be VERY careful in any bush pile work though.
The 12 hp Gravely never bogs down with a 30" hog on it. I've heard that they'll toss football-sized rocks. Prefer not to do this on mine.
Ralph
/ bx1500 questions #4
(Will they run a 54 inch deck ok. Dealers around here keep try to get me to get a 48" deck but I think it is because it is what they order)
I cant speak about the 1500, I have a bx 22 w/ a 60 mmm, and it just amazed me this past summer. I cut the lane for my neighbor, the grass was like 8" tall and i cut it down to 4, going alomst as fast as the machine would travel, only had to slow down when it was really thick, I was very impressed.
(Also how well do the baggers on them work. Sales guys keep trying to talk me out of a bagger. )
I have the bagger as well, mostly only use it to pick up leaves in the fall here in michigan. It works good. The hose will plug up when the leaves get really thick, you have to go pretty slow. The few times i have used it on grass, it has worked great. You barely know its beck there. However, i do need to say, it can be a trick to hook up to the tractor. You dont want to take it on and off all the time, like i do whith the BH and all.
Hope that helps /forums/images/graemlins/cool.gif
/ bx1500 questions #5
</font><font color="blue" class="small">( So, I'd think the BX1500 would power the 54", but my cabinet maker, who just bought a BX2200, commented that the weight of the thing back there could be a factor to consider. )</font>
I'm pretty sure the poster was talking about the 48" vs. 54" mid mount mower, not rear mount bush hogs so weight should not be a significant factor in his decision. According to my brochure on the BX1500 the difference is 62 pounds.
/ bx1500 questions #6
My bx1500 plays with the 54" deck. Look at both carefully. The 48 is a piece of tin and has to be dragged out. The 54 is heavy steel and the wheels rotate to allow for moving out on its own wheels.
/ bx1500 questions #7
Sorry about my digression on bush hogs.
I'd think that the BX1500 should handle even a 60" deck. It would stick out further and allow you to get closer to shrubs and stuff.
Prorate 15/12 x 50 = 62.5", from Gravely experience. Gravelys are mulching decks, too. They take more Hp.
Ralph
/ bx1500 questions #8
Chas --
Regarding the "slot," I think we had a discussion about this sometime in the past and concluded that it has various uses depending on model. For example, on the BX23 this slot is used for the female end of the seat belt, since the seat belt needs to be a bit further away to allow the seat to rotate for backhoe operation.
On other models (BX2230, etc.) it is used for the "cruise control" lever, and the seat belt end comes up between the fender and the seat, IIRC. (I've never seen a 2230 in person, but someone posted a picture of the lever.)
I was thinking that all of the new BXxx30 models have cruise control -- maybe you were looking at a 1500 rather than a 1530??? Or maybe no CC on the 1530 -- dunno.
/forums/images/graemlins/tongue.gif
/ bx1500 questions #9
I have a 2004 bx1500 that I got in the end of November from a dealer that seems to only sell 54" decks because the design is better with the rotating wheels, and it is made stronger. My mower has not been installed since the day of delivery. As for a way to keep the 3 point hitch up, there is a hitch lowering speed knob, that the manual states that it can be turned to a lock position, but I have not tried it yet. There is also holder holes to hold the lower links higher while mowing, but I don't think you could use them with an implement attached. I thought about a bagger for leaves, but I can just as easily blow them away where I live. I, too, have an acre all on a slope and the 1500 feels the right size for it, especially compared to my previous lawn tractor.
/ bx1500 questions
Thanks for the reply guys Sorry I have not been back. work sent me out of town.
Anyhow I know what everyone says about looking at bigger than you need but right now I have a 12 hp Murray that is 10 years old and still in fairly good shape (well for a 10 year old Murray) so I feel I am looking much bigger. Besides a 1830 or 2230 would be to big for my yard
and yes I was talking about the mid mount mower
Does Kubota offer extended warranties? are they money well spent or are the botas "that good" that I don't need one?
One guy said something about a bx1530 but a dealer "told" me that nothing changed on the bx1500 for 04 so I assumed there was not a bx1530.....
Well at work if I have to buy/sale big stuff I have to do a ROI (Return on investment) maybe the dealer will do a ROI for the wife.....wait better yet maybe I can trade her in on a bx
/ bx1500 questions #11
Chucko,
I cannot give specific advice on the BX1500 as I have the BX1800. But I can tell you I love my 1800. As for the Grass Catcher/Bagger, here is a link from last year that has quite a bit of information from a few of us who have them. I can say without hesitation that it performs very well, at the same time I can also say without hesitation that the attachment and removal is a pain in the U know what (censored by myself /forums/images/graemlins/grin.gif ).
I suspect the 1500 is also like the 1800 in that the same lift is used for the deck and 3-point. You cannot raise lower the deck without also doing it with the 3-point unless you unhook the 3-point lift arms. You can however put the deck in a "top" position that allows you to use the 3-point without lowering the deck.
http://www.tractorbynet.com/forums/showflat.php/Cat/0/Board/owning/Number/255265/page/0/view//sb/5/o/all/fpart/1/vc/1
Good luck on your choice,
/ bx1500 questions #12
Heck if she's on a BX you don't have to trade her in, you just have to convince her to give you a turn /forums/images/graemlins/grin.gif
/ bx1500 questions #13
Changes in the 04 bx1500 are minor and include a new differential lock pedal, and a new hood release. If I'm on mine this weekend, I'll see if the 3 point hitch lockout knob will do what you were asking.
/ bx1500 questions #14
My immediate supervisor and I purchased a BX1500 this past summer. At the time I wasn't sure how get her "approval" so I just tried "buy-in". I illustrated the features and financing plus they were available for try-out at the local stock show. That did it, when we went to get an orientation at our dealer prior to delivery she drove it first. It arrived at our place on a Friday afternoon I got to play with the loader. Saturday she climbed aboard and proceeded to mow with the finish mower the easement and some other spots around our 1.5 ac.. Since July I've only mowed once. She says it's a diversion and good therapy from the__ _ at the office. Hang in there it will happen. Good Luck!
/ bx1500 questions #15
My cabinet man recently traded in his 2wd JD for a BX220. He's not been able to mow because his wife does it all.
He says it's not a JD, that the JD makes everything a bit smoother. Guess you'd have to live with both to know this. I get the idea that he'd never have traded if his JD had been 4wd. He bought for the price.
Ralph
/ bx1500 questions #16
On a 2004 bx1500, I was able to use the 3-point hitch lowering speed knob in a lock position to stop the movement of the hitch arms. Without the weight of the uninstalled mower deck present, I could not tell whether the hitch lockup allowed the movement of the mower deck. I would guess it has nothing to do with the deck, but I may be wrong.
/ bx1500 questions #17
Chucko,
I own a BX1500 and like you an acre of property to mow. I am very satisfied with the BX1500 with the 48” deck. It is a very well made deck constructed of the same 10 ga. steel as the 54” deck. It does not have the pivoting wheels to roll out on, but on smooth concrete it slides out from under the tractor like it is on rails. For property your size the 48” is plenty big.
As far as the getting something bigger than you need right now, for me the BX1500 already is. All I could really justify for a yard this size, being used 99% of the time for mowing, was a big Murray or a Craftsman, but I always wanted a Kubota so I sprang for the extra $5000-$6000 and got one. With proper care this tractor could easily last the rest of my life. If your 10-year old Murray is in good shape, you will probably get 30 years out of a BX, no problem. It also has the capability of performing many more task than a Murray or Craftsman.
The 2-cylinder engine does idle very rough, which is normal, but is smooth as glass above a fast idle. I seldom idle mine all the way down, to prevent it from shaking so hard. Once you know this is normal for a 2-cylinder, it is not a problem. As far as I know it doesn’t have any extra balancing shaft or flywheel, but does have a large chunk of cast iron attached to the top of the engine to dampen the vibration. I ask here once if anyone knew exactly how this works and got no responses, so I assume no one knows.
You can lock both the mid and rear lift in the up position with lowering speed adjustment knob, but not separately. You can lock the deck up with the height adjustment knob while still operating the rear lift, but not vise versa.
The only other downside of a BX over a Murray other than initial cost is that it is a much more complex machine than your Murray and will require quite a bit more maintenance and expense to maintain it properly.
/ bx1500 questions
OK I guess all I need now is "buy in" from the wife
Can someone give me an idea of how much at DIY service would cost on this tractor and how may times a year (avg) you need to do them?
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
Deutz D3006 Tractor (A62613)
Deutz D3006...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2007 International 8600 Truck (A62613)
2007 International...
