BX1500 Its here!!!!!!!!!!! Pics
/ BX1500 Its here!!!!!!!!!!! Pics #1
Apollo
Manitowoc Wisconsin
2004 BX 1500
Arrived this morning!!!!!!!!!!!
Excellent service from Feldmanns sales and service in Howards Grove I might add also. They are a family owned buisness and the attention to the customer really shows and they have my recommendation any day.
But I did discover one problem already which i will attach pics of.
The belt for the mower deck is rubbing on the tension pulley arm. The bottom of the belt after 20 minutes of use is already wore leaving a large amount of rubber on the top of the deck and a slight groove/wearing of paint on the arm where the belt is rubbing on it. It looks as if the arm is slightly bent up where the spring attaches to it. I called the dealer and they are ordering a new arm and belt but i am wondering if anyone else had this problem with the 54" mmm deck at any point???????? The belt is also riding on the bottom of the pulley.
Anyway im glad to be here and hope to help out in the future.
Here is a link to the pics.
http://www.tractorbynet.com/photos/showgallery.php/cat/500/ppuser/15116
/ BX1500 Its here!!!!!!!!!!! Pics #2
Very nice! I've been really pleased with my BX, hope you will be as well.
/ BX1500 Its here!!!!!!!!!!! Pics #3
I have the 60" MMM on my BX and I have not experience any wearing of the belt. My BX is about 4 months old.
Hopefully your dealer will get this fixed with the new parts they ordered.
/ BX1500 Its here!!!!!!!!!!! Pics #4
<font color="blue"> I called the dealer and they are ordering a new arm and belt but i am wondering if anyone else had this problem with the 54" mmm deck at any point???????? The belt is also riding on the bottom of the pulley. </font>
I would be concerned. Possibly to the point of telling them I wanted a new mower deck. Brand new machine, and all that.
Was the mower somehow damaged in shipment? Was it put together by a welder that was hired away from King Kutter?
No reason why for the price the mower deck should not be perfect upon delivery.
Strike while the iron is hot, so they say. If you accept it as is, you will live with it a long time. Maybe there is a simple explanation, but be careful...
Tell them to bring you a new mower. Why should you accept a repaired unit at the price of new?
Sounds harsh, but think about it. If you bought a TV or something and brought it home and it failed in 20 minutes, would you keep it or take it back to the store and get another, new one?
Myself, I am a pretty reasonable guy for the most part, but I doubt I would be happy with a repair if I were in the same situation. When I buy new, I expect what I buy to work perfectly for a while...not have problems during the first half hour.
Also, ask them how many pumps of grease they put into the mower spindles before delivery. If they say "none, they are greased in the factory"...from what has been reported here on the 60 inch deck for the BX18/2200 you may have run the spindles almost dry...another reason to push for a new replacement.
Sorry if this sounds like gloom and doom...just trying to share concerns I would have if I were in your shoes.
/ BX1500 Its here!!!!!!!!!!! Pics #5
I am in full agreement with Henro (Bill) on asking for a replacement. I was going to post that, but I got involved watching a e Bay auction and didn't get to it... He saved me a lot of typing... thanks Bill..
PS... I didn't win the auction.. /forums/images/graemlins/mad.gif /forums/images/graemlins/frown.gif
/ BX1500 Its here!!!!!!!!!!! Pics #6
As usual Henro is right on. I have just over 50 hours on my 23 and the deck sounded kind of noisy at first. Well I took it off and greased it up real good, funny the noise was considerably less after that. My guess is that they did not grease it up enough. I also agree, I would get a new mower deck, not have this one fixed. He made enough on the deal to deal with a picky customer (you), and not get his feelings hurt.
The arm looks like a easy swap but im not 100% sold on it being the sole problem. Its possible the gear box pulley sitting right next to it is to low causing the pulley to ride low and rub the arm on the belt tensioner pulley.
I plan to let him swap the arm and then look at it. If it lines up good then fine. If not I am not going to mess with trying to move the gearbox, im going to ask for a new deck.
Thanks for the suggestions.
I also discovered that the arm on the right side of the tractor that raises the deck hits the bottom of the floorboard. I was told to just adjust it so the deck sits lower.
In looking at the front links on the mower attachment i see that the threads are backed way out and also on the side to side adjustment threads underneath by the arms they are backed out quite a bit. Im no mechanic but couldnt they be tightened to raise the deck some so the arms dont hit the bottom???????
If you blow up picture number 126-2625_IMG
that i have posted you can see the front nuts i am talking about by the bottom of the front grill..........its for the front hanger for the deck.
/ BX1500 Its here!!!!!!!!!!! Pics #8
I wouldn't do any adjustments on the deck at all.... Let the dealer do what is necessary. To me, it looks like the set up person never did the set up on the deck and that possibly the entire deck has been "racked" or damaged in some way. It could have been dropped in shipping and show no outward appearance of damage, but the unit itself could be out of alignment.. I have looked at the pictures and believe that the belt is riding too low in the pulley. Pictures can be deceiving, so take that for what it is worth. Either way, let the dealer do what is necessary to repair this. For the next year, the deck is his problem.... 1 year warranty on the deck...
/ BX1500 Its here!!!!!!!!!!! Pics #9
Not to be hard, but make the dealer do this setup stuff, since it was apparently not done correctly at the dealers. Do not touch it, make them. These things should have been found out and fixed or replaced BEFORE delivery (maybe why yours was LATE), but even if you are able to do them, you should not and you should not have too. My dealer run checks all his sales BEFORE they go out, he has the yard to prove it, and they would not go out like this.
If he balks, a quick call to Kubota home office should do the trick, but my guess is, that would not be needed.
Let us know
/ BX1500 Its here!!!!!!!!!!! Pics #10
I would want a new deck out of the deal.
Obviously they have not setup the deck as I can plainly see the caster wheels are not the same on the front and rear of the deck.
Mine was delivered not setup either and I called the Dealer immediately as I specifically told them to set it up for 3" mowing.
They sent a truck to get it and delivered it when they had it properly adjusted!
Good Luck, Tom
Update:
Problem was fixed today..........Was a bolt which was resting crooked which held the tension pulley.......Took it out reseated it and good as new......
Now have 4 hrs on it and am enjoying it. I installed a Tiny Tach today and will post some pics tomorrow.
I also found out that with the new style hood releases on the 2004 models you have to check under the dash and make sure the hood release when pressed does not hit any of the wires for the temp gauge. I was under there messing around with routing the tach wires and saw the hood release where it would hit the wires. Eventually probably causing damage to them or the gauge.
I also got to compare the b1550 with the bx1500 today as my uncle has the 1550................No comparison...........the 1550 with 4x4, Hst, and bi speed turn is a much beefier tractor with more usable features but definitely was much more expensive as it was $16000 14 years ago!!!
DSP 900 Balancer with Split Weight (A63689)
DSP 900 Balancer...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
EZ-GO Electric Golf Cart (A64127)
EZ-GO Electric...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
