BX15 vs BX18/23
   / BX15 vs BX18/23 #1
jbordwine
SW Virginia
2003 Kubota Bx1500
Hey guys, I know I could probably find the answer by searching but I've been really busy at work. I have a 2003 BX1500 w/ 54" MMM 254hrs. Its a great little tractor! I just purchased an additional 2 acres that adjoins my current property which puts me near 5 acres total. My BX15 mows great on level land but I mow at least 2 acres that is sloped. Its not overly steep but steep enough that my BX15 has to be put in low range to mow, I keep it in 2wd. It pulls the hill fine in low but bogs down in high range. First off I assume this is normal? Second, I have found a couple of BX1830's and one BX2300 that have low hours that I am considering. Would the 3 cylinder engines allow me to mow in hi range without stessing the engine/transmission?
   / BX15 vs BX18/23 #2
The extra torque you will get from the 3 cylinder engines in the larger BX tractors may or may not enable you to mow in high range. Will you step up to the larger 60" deck with the larger tractor? Is the extra weight of the larger tractors enough to prevent mowing in high range? You really need to have one brought out to your property to find out for certain.
On another note, would stepping down to the 48" deck enable your 1500 to handle the mowing chores in high range? You're losing some cutting width but potentially picking up mowing speed.
   / BX15 vs BX18/23 #3
Your model numbers are confusing, as some of them do not exist. I figure BX15 means BX1500, but othere are just a guess. These are the BX model numbers:
1500, 1800, 1830, 1850, 2200, 2230, 2350, 22, 23, 24. A new model for release soon is the 2650. Four digit numbers do not have a Kubota backhoe available. Two digit numbers come with a backhoe as a TLB unit.
There is no BX2300, so it is unclear whether you mean BX23, which has a bh, or BX2350, which does not.
   / BX15 vs BX18/23 #5
Hi
I have a BX1830 and though it will cut in high I don't recomend it as it is just not safe in wide open throttle
This was my dealears recomendation also
Regards
DGS
   / BX15 vs BX18/23
I'm not talking about wide open throttle, just a little faster than what can be done in lo range.
   / BX15 vs BX18/23 #7
I always mow at 'near' wide open throttle (BX1500) and always in Hi. Got to keep up the blade speed and HST at max output. I rarely see a problem going up steeper parts of my yard - only when I try to go at top speed uphill in deep grass, then it will bog down. I just slow down (speed, not throttle) until I get thru it.
   / BX15 vs BX18/23 #8
It really depends of the total amount of kinetic energy being lost as the blades engage the grass. The energy loss is a product (literally a multiplication product) of two things: the sharpness of the blades (in this case an inverse of sharpness, e.g dullness) and the resistance of the grass.
I always run the tractor at full throttle. The range that you are in is not a factor when cutting grass like it is when you are plowing. If I am plowing in duripan with the subsoiler, I cannot even move in high range because the torque is too low. In low gear, with higher torque, I can move.
Rather than which range, the actual speed is what matters. The faster your velocity, the more grass there is that enters the deck in a given time. Each rotation of the blade must cut a greater volume of grass and expel or mulch it. In sparce grass that only needs a slight trim, I can cut at full speed in high range. If I have waited too long and the grass is both thick and tall, I have to creep in low range or risk stalling. In either case I want the throttle at full so that the blades are spinning at the highest possible RPM. The blade speed is completely independent from the range that the drive system is in, and the torque to the drive wheels is not as significant of a factor as when plowing. Obviously, when all other factors are the same, a larger deck is cutting more grass per unit of time, and is therefore experiencing greater resistance. This can be compensated for by reducing speed such that the volume entering the deck is equal, as is the area in square units that is being cut. Also, more total energy is being lost to gravitational resistance when traveling uphill as opposed to downhill. In a couple of steep locations, while brush hogging, I cut only while traveling downhill. I do not cut as I return to the uphill location for another pass.
The other factor, blade sharpness, speaks for itself. Far less energy is absorbed by the grass stems when a sharp blade slices through them, as contrasted with a dull blade ripping the plant tissues apart.
Ideally, you want max sharpness multiplied by max RPM of the blades. The variable is the forward velocity of the tractor. Regardless of range, the maximum forward velocity should be the speed at which you do not lug down from resistance in the MMM deck, AND you get the cut quality that satisfies you on the lawn surface. It is possible to cruise at a speed at which there is no lugging, yet the cut is not as clean as it would be at a slower velocity.
The greater weight of the tractor will not be a factor as the greater hp more than offsets that. The greater number of cylinders any recirocating IC engine has, (assuming bore and stroke, fuel, all other factors, etc. stay the same) the better the torque. In a 4 stroke engine, the crankshaft rotates 720 degrees between the time one cylinder fires and the time that it fires again. In a 2 cylinder engine, the crankshaft has to turn a full 360 degrees so that the first cylinder is beginning its intake stroke as the second cylinder begins its power stroke. After the power stroke, everything depends upon the internal inertia for the first piston to complete its exhaust stroke while the second is making its compression stroke. In a 12 cylinder engine, the crankshaft has moved only 60 degrees following one power stroke, before there is another power stroke. There is always pressure from at least two cylinders and power is not petering out. In a three cylinder engine, the crankshaft has to travel 240 degrees from power stroke to power stroke. In comparable engines with differing numbers of pistons, the greater the number of pistons, the more smoothly and constantly is the energy applied to the crank and drive shafts. Therefore, the three cylinder engine is more efficient than the two cylinder engine.
Hope this helps. Good luck!!
   / BX15 vs BX18/23 #9
I think your slope must be steep enuf that your relief valve is relieving in hi range. Otherwise you could just back off on the pedal and proceed at low gear speed and the tractor would cut as if it were in low gear. In Hi you would be pumping a small amt of fluid at high pressure to get your wheel torque. In Low you would be pumping more fluid at correspondingly less pressure. As long as the hi pressure required to move uphill in Hi does not exceed relief pressure you dont need to shift to Low, and there will be no performance penalty for running in Hi.
larry
UNUSED LANDHONOR LHR-SL2T3M CHAIN HOIST (A54757)
UNUSED LANDHONOR...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2021 Chevrolet...
2012 Jeep Liberty SUV (A53424)
2012 Jeep Liberty...
UNUSED WOLVERINE TQH-26-02C CLASS 1 QUICK HITCH (A54757)
UNUSED WOLVERINE...
7046 (A50322)
7046 (A50322)
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
