BX wheel weights vs other brands
   / BX wheel weights vs other brands #1
RaydaKub
Veteran Member
Rochester, MN
Kubota BX2230
My BX2230 is way too light on the back end. I filled the tires, but need more for FEL work. I've see gobs of 12" wheel weights on ebay and craigslist, but they all have 4 bolt holes. My rims have 5 bolts. Is my only option to buy new weights from the dealer (or wait for some nearby). I assume none of these 4 hole weights will work. I may have to do a 3ph weight also, but on my side hills I want it low and wide.
   / BX wheel weights vs other brands #2
Don't confuse the 5 bolts with the 4 square holes ;)
   / BX wheel weights vs other brands #3
The wheel weights I had with my BX had nothing to do with the 5 lugs.
They used the 4 holes in the wheel of the BX. An 8" long threaded rod went through the the wheel weight and through those 4 holes. The bolts used washers and nuts on both ends. Each weight was approximately 50 lbs, so they added 100 pounds, but absolutely at the right place. They worked very, very well.
   / BX wheel weights vs other brands #4
Pretty much like BP's.
Hey guys, thanks for the tips. I never noticed the outside of the rim had those holes in them. I'll start hunting right away. :)
BP, that's a mighty clean tractor. Have you even started the engine on it yet? :)
A couple other thoughts. First you said to use an 8" bolt to mount them. I see 2 bolts on a couple of those pictures. Is that enough for a 75lb weight? Or should I use 4 on that much? Do all the brands pretty much use a standard spread for the bolt pattern so they'll all fit each other?
You guys are terrific. And FAST! :)
   / BX wheel weights vs other brands #7
Thanks, but that tractor got sold a year ago. That photo was one of it's "glam shots' for the advertising and for my fond memories of the tractor. It was sweet.
   / BX wheel weights vs other brands #8
Honestly don't know as mine came dealer installed. Had I done it myself I probably would have used all four just because there are four holes, but no problems to date.
The full weight is not being supported by the bolts.
   / BX wheel weights vs other brands #9
The square holes are actually intended for carriage bolts. No nuts and washers needed on the inside.
   / BX wheel weights vs other brands #10
True enough, but mine came from the dealer with just long threaded rods and nuts/washers. Not ideal, but they held.
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A43004)
2015 FREIGHTLINER...
PALLET OF PIPE FUSION EQUIPMENT (A45333)
PALLET OF PIPE...
2015 Ford F-350 Flatbed Truck, VIN # 1FD8W3GT8FEB06139 (A44391)
2015 Ford F-350...
53’ STEP DECK  MIXER TRAILER (A45046)
53’ STEP DECK...
2024 VALLEY PIONEER STAND ON MINI COMPACT TRACK LOADER (A45046)
2024 VALLEY...
2012 CAT D5K2 Dozer (A42203)
2012 CAT D5K2...
