BX wheel weights vs other brands
/ BX wheel weights vs other brands #1
RaydaKub
Rochester, MN
Kubota BX2230
My BX2230 is way too light on the back end. I filled the tires, but need more for FEL work. I've see gobs of 12" wheel weights on ebay and craigslist, but they all have 4 bolt holes. My rims have 5 bolts. Is my only option to buy new weights from the dealer (or wait for some nearby). I assume none of these 4 hole weights will work. I may have to do a 3ph weight also, but on my side hills I want it low and wide.
/ BX wheel weights vs other brands #2
Don't confuse the 5 bolts with the 4 square holes ;)
/ BX wheel weights vs other brands #3
The wheel weights I had with my BX had nothing to do with the 5 lugs.
They used the 4 holes in the wheel of the BX. An 8" long threaded rod went through the the wheel weight and through those 4 holes. The bolts used washers and nuts on both ends. Each weight was approximately 50 lbs, so they added 100 pounds, but absolutely at the right place. They worked very, very well.
/ BX wheel weights vs other brands #4
Pretty much like BP's.
Hey guys, thanks for the tips. I never noticed the outside of the rim had those holes in them. I'll start hunting right away. :)
BP, that's a mighty clean tractor. Have you even started the engine on it yet? :)
A couple other thoughts. First you said to use an 8" bolt to mount them. I see 2 bolts on a couple of those pictures. Is that enough for a 75lb weight? Or should I use 4 on that much? Do all the brands pretty much use a standard spread for the bolt pattern so they'll all fit each other?
You guys are terrific. And FAST! :)
/ BX wheel weights vs other brands #7
Thanks, but that tractor got sold a year ago. That photo was one of it's "glam shots' for the advertising and for my fond memories of the tractor. It was sweet.
/ BX wheel weights vs other brands #8
Honestly don't know as mine came dealer installed. Had I done it myself I probably would have used all four just because there are four holes, but no problems to date.
The full weight is not being supported by the bolts.
/ BX wheel weights vs other brands #9
The square holes are actually intended for carriage bolts. No nuts and washers needed on the inside.
/ BX wheel weights vs other brands #11
Why not just load the tires with fluid? It's simplier and cheaper in most areas.
/ BX wheel weights vs other brands #12
There was only five dollars difference in price on mine.
/ BX wheel weights vs other brands #13
The BX is small enough that putting the wheel weights on/off is manageable for a homeowner type person. There are those situations where the owner does not want the extra weight. Wheel weights provide an option, whereas filling tires is a rather full time commitment to the weight.
I did that. 10 gallons of -35 washer fluid plus 1 1/2 gallons of water. Right after finishing this, I drove it to the steepest part of my lawn. I have mowed this area for years with my little green STX 38, but I usually slide one cheek onto the fender. I parked my BX and got off, pushed on the roll bar and easily lifted the rear wheel off the ground. Granted, I had my FEL on yet and I will normally drop that to mow, but that told me that I could certainly do better yet.
Made me really wonder about my pucker factor that I had mowed it the first time with the BX, tires unloaded, and FEL on. Yikes!
No spacers. I'm not sure if I could. I looked at my mower, and while it seems to cut just fine, it appears the previous owner may have smacked it into something and bent it backwards some. I'll have to look at it. It's the 60 inch.
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
Ford 2000 Tractor (A65579)
Ford 2000 Tractor...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
Hercules 25 Gal Sprayer (A64127)
Hercules 25 Gal...
16ft. T/A Utility Trailer (A64557)
16ft. T/A Utility...
PREVIEW DATES AND TIMES (A65579)
PREVIEW DATES AND...
