bx weight box removal
/ bx weight box removal #1
shrekbelly
perhaps, i should have selected a screen name like "bxboob," instead of shrekbelly? . . . but i need assistance in the steps required to disconnect the lower 3ph arms from the weight box. there is no mention in tractor manual.
would someone please explain the steps to me? thank you for your time and attention. shrekbelly
/ bx weight box removal #2
You have to loosen the stabilizers so that you can swing the lift arms out and off of the lower pins of the weight box after removing the retaining or "lynch" pin. Then remove the pin from the top link and that should be all you need to do. Sometimes you can put the box down on some 2X4's because it might not quite touch the ground when all the way down.
/ bx weight box removal #3
Better yet, lower the weight box onto a standard mover's dolly so you can manipulate it once on the ground. Makes removing the lower arms from the box's pins much easier.
/ bx weight box removal #4
Mine is filled with sand bags. I unload them from the box before removing it which makes it a whole lot easier to wrestle with.
/ bx weight box removal #5
Think...think a...think a...think ah...darn it! What's that think you're supposed to do before trying to move 700# of sand by hand?
[google search]
Think AHEAD!!! Wow! Look at you go! You must be a rocket surgeon.
Honest to goodness, that's a good idea that I'm not sure I'd have done. I'd have just poured a whole pile of stone in there and said 45 seconds later, "OK, how to get it out now..."
/ bx weight box removal #6
This is what I do. Only other thing I can add is that I use a crow bar between the box and lower link ends to "pursuade" the arms to come off the pins. Sometimes a little WD-40 doesn't hurt either. A quick hitch would be nice for this application, just don't have one ..... yet!
