BX Transmission Filter Change
/ BX Transmission Filter Change #21
Are you guys really that cheap that you can't afford to change a few gallons of oil at 50 hours? Just imagine how broke you'll be when you lose your transmission from lack of maintenance.
/ BX Transmission Filter Change #22
The fluid from my BX1860 had small flecks of shavings in it. I replaced the oil, and also lost the annoying whine that my tractor had. My new B2601 will have the same service when it reaches 50 hours. Engine oil, filters and strainer as well.
/ BX Transmission Filter Change #23
I did all the fluid on mine at 50hrs and used sudt2. I was advised that it was a waste of money, but I like that it doesn't whine near as much.
/ BX Transmission Filter Change #24
I don't have a BX but my 3 hydro Kubotas had lots of large chunks on the magnet at the filter, but they were on the dirty side, not the clean side. My L5740 has now had 3 changes and I'm still surprised at how much crud the magnet collects; however, this is all from the transmission housing and all oil goes through 2 filters before it gets to the hydro.
A reason for using SUDT2 is it's improved cold flow properties. Having a suction filter, the noise is lack of oil at the pump(s). Yes you will save $$ on oil changes and if you don't use your tractor too many hours, you probably won't notice the component life reduction. Also users in the south won't have problems seen in the colder tiers. My dealer told me that since I kept the tractor that gets used in the winter in a heated garage, I shouldn't spend the extra bucks but I thought about the cost of the oil vs the cost of a transmission rebuild and figured why not. Probably overkill but it's much less expensive than a breakdown in the middle of a job.
/ BX Transmission Filter Change #25
I'd change the oil for peace of mind. Small potatoes in the big picture. Just my $0.01 and the way I do things.
/ BX Transmission Filter Change #26
A picture is worth a thousand words.....BX22 strainer screen.
All hydraulic oil drained out when screen was removed have catch pan ready.
/ BX Transmission Filter Change #28
A friend of mine changed just the spin on hydraulic filter on his bx and the only fluid he lost was the fluid in the filter. No vacume cleaner was used, no jack stands and no jacking the tractor up on one side. He just spun the filter off and spun the new one on. No mess no fuss.....I know I was standing beside the tractor when he did it.
Pulling the suction screen is a whole different ballgame. I you pull the suction screen with out draining the fluid before hand you will have a huge mess to clean up.
/ BX Transmission Filter Change #29
You won't lose much fluid by just changing the filter, especially if you're prepared and make reasonably quick swap.
On the screen, being prepared with a 1" tapered rubber stopper plug and you'll lose only an ounce or two of fluid. Just another option to the vacuum method if you don't have a helper or shop vac. These cost only a buck or so at your local hardware store. You can pull that screen and clean it whenever you wish with no meaningful fluid loss.
Most all this is just a matter of being prepared to do the job.
/ BX Transmission Filter Change #30
You won't lose much fluid by just changing the filter, especially if you're prepared and make reasonably quick swap. On the screen, being prepared with a 1" tapered rubber stopper plug and you'll lose only an ounce or two of fluid. Just another option to the vacuum method if you don't have a helper or shop vac. These cost only a buck or so at your local hardware store. You can pull that screen and clean it whenever you wish with no meaningful fluid loss. Most all this is just a matter of being prepared to do the job. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464587"/>
Yes the cork works great. Just be ready.
/ BX Transmission Filter Change #32
Question for ehenry...how many hours did you have on that screen? I changed mine at a little over 400 hrs. Yours looked a lot like mine...quite a few charp metal pieces on it.
/ BX Transmission Filter Change #33
Warment, Sorry to say but I have no clue how many hours were on that change. I inherited that tractor from an old friend that passed away and knowing him, I really don't think it had ever been changed since it was new. The tractor had 1200+ hours on it when I took possession of it. I"ve done quite a bit of maintenance and repairs to it.
As for driving up on ramps, using shop vacs and such to save your oil I guess its to own their each. The BX22 only holds 3.5 to 4 gallons of oil I drained it all and replaced it. If it was a big tractor that holds 10 to 20+ gallons of oil I could understand the methods people have used.
/ BX Transmission Filter Change #34
Thanks ehenry. I was just curious since I recently changed the hydro fluid/filter in my BX2200 and mine had little pieces of metal on the screen like yours did. My tractor had slightly over 400 hrs and I think the hydro fluid/filter had been changed at least once since the filter had a 2007 date written on it with a grease pencil. I recently changed both the supply and return fuel lines and filters as well. Have you changed the fuel lines yet?
/ BX Transmission Filter Change #35
The thing that makes me think the hydraulic fluid and filter hadn't been changed is the filter was the same color as the frame of the tractor and no numbers were on it. I have not had to change any of the fuel lines. I have had to drain the tank completely and put new fuel filters on. The things that are getting changed on a regular basis are the hydraulic lines on the back hoe and FEL. They are showing their age and springing leaks. I think I have 6 more lines to replace on the back hoe and they will all have been replaced. Four more lines on the FEL. I've also had to replace the hydrostat fan, replaced the CV joints and boots as well as the fan belt while I had the propeller shaft out. Since I don't have a MMM I've installed a BXpanded skid plate so hopefully I wont have to do the fan job again.
I also inherited a B7300 as well. Its next on the list for love and care......the main thing on it is fuel is leaking at the injector pump. Its coming from under the flanges where the fuel supply lines connect. From what I've seen on the web and youtube there are some O-rings that need to be replaced but I'm having a problem finding someone that carries the O-rings.
I see the thread is still going so another question . . . .
I drained the fluid figuring I'll just spend the money for a little peace of mind. Also pulled the strainer - very little to no metal flakes (55 hours on the tractor). But - how to get the #%$$^$^ filter off. Hard to get to as it is with the mower deck on and evidently the factory puts the initial filters on tight as a drum. The oil filter I loosened up with a pipe wrench (yes, a pipe wrench) but the transmission filter is tight to the case on one side - no room for anything but a band type wrench. Now these filters are smaller than my car wrench fits so shimmed that with a thick strip of rubber. No luck - the thing is on so tight the band wrench with rubber strip slips before getting sufficient grip. So I bought a wrap up band wrench from the dealer and will try that this weekend. Meanwhile I've been without the tractor for a week and the grass is growing. Any suggestions? Most likely will have to jack the rear of the tractor up for better access (on stands of course).
/ BX Transmission Filter Change #37
Sam, I know you don't want to and are trying to keep from it but is removing the deck an option?
/ BX Transmission Filter Change #38
Deck removal is a snap. Not sure about reinstallation since I havent done that yet. I too would say to bite the bullet and remove the deck.
/ BX Transmission Filter Change #39
It's easy to put the deck back on. You tube has videos that show how.
The wrap up wrenches kinda stink in my experience.
I remember my filter was REALLY TIGHT. Can't remember if I used my big azz channel locks or the right size band wrench.
/ BX Transmission Filter Change #40
Put the pto in rear only when you hook up the belly mower shaft. It leaves the mid pto in neutral that way, so the shaft will move enough to line up the splines.
International 1486 Tractor (A66285)
International 1486...
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
Peacock (A64557)
Peacock (A64557)
100 Manure Spreader (A66408)
100 Manure...
2017 Toro GrandStand 52in Stand-On Mower (A64553)
2017 Toro...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
