Bx to B series
   / Bx to B series #1
chocolatehauler
Harbor Springs Michigan
Bx2200
anyone know if a bx 60 in deck or front blower will fit on a b model. reason for asking is I'm thinking of getting a larger machine. Reasons for possible change is fel with more lift and more ground clearance.
   / Bx to B series #2
Don't know for sure about the blower, but you'll need a new deck to go along with the B...the BX deck is just for the BX tractor...they're quite a bit different in the mounts.
I would guess that the blower mounts will be different as well, unless you're handy with a welder and have some spare time on your hands. /forums/images/graemlins/smile.gif
   / Bx to B series #3
I'm not 100% certain, but I don't think a front mount snow blower from a BX will fit on a new B model (without making new brackets). Maybe they would fit a late 90's B model.
What B model are you looking at? It makes a difference. The new B models have completely different brackets and such. The slightly older B models B2100, B7300, B2400 share a common frame; so things are more interchangible amongst those three. The newer B models have a new bracket system that won't fit on the older B's (I tried that approach). The BXs have a smaller frame and might require shorter mid-mount PTO shafts.
1997 CMC S102 END DUMP TRAILER (A53843)
1997 CMC S102 END...
Electric Mobility Scooter (A54815)
Electric Mobility...
2009 DRAGON  130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
Informational Lot - Shipping (A53473)
Informational Lot...
