edwardthe3rd
- Joined
- Nov 2, 2010
- Messages
- 7
- Tractor
- BX24
Hi, folks..
I bought a BX24 3 springtimes ago. From the first week I had mine, it would occasionally simply not start. I discovered after a time all of the traps created by dead-man switches, including once when the one under the seat which is very cheaply made, and which broke off with almost no provoking. But there were times which were just unexplainable. I would turn on the switch, hear the relay click, and nothing... then I would hear what is assume is the solenoid plunger, snap back into position. After sitting for a while, I would try again and the engine would turn over and start immediately --- nothing different done by me. In a car this is usually a sign of a sticking solenoid.
This morning I went out.. been using the BX all winter to move snow and haul wood, and now I want to put the tiller on it, but it does the same routine again. I turn it on to glow and it ticks, then I turn it to S and nothing. I release the key and 2 seconds later I hear the sound of something spring-driven popping back into place.
What do you all think? Did I get a bad starter in the first place? Or is it a damned deadman switch again? Whatever advice I can get to test it, starting with the simplest and cheapest first, would be greatly appreciated.
Thanks.
Thanks.
