BX Seat Belt is Killing me, HELP
   / BX Seat Belt is Killing me, HELP #1
woodstock
Winnipeg, Canada
BX2200
What is it with that seat belt? I buckle it up and everything is Ok. Then after about 5-10 minutes of concentrating on the chores at hand I begin to feel like I sitting under the tractor not on top of it.
That seat belt could even keep Viagra down.
Is it my belt or are they all like that?
Any suggestions, my voice has gone up three octaves.
Some day I may want to have kids, na I'm already too old.
Please help.
Winnipeg, Manitoba
2001 BX2200 All Kubota FEL, Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
Grey market B7000 w/Tiller (120 hrs)
1984 JD 316 after 687 hrs.
   / BX Seat Belt is Killing me, HELP #2
Mine seems fine (BX1800) - only suggestion is a clip on the belt - sounds like it would be worth the trouble. Actually, I've been so thrilled by my tractor I'm not sure I would have noticed the belt tightening, and yes I do wear it when using the FEL
Gerry
   / BX Seat Belt is Killing me, HELP #3
My seatbelt tends to tighten up on me after bouncing around on rough ground for a while. I stop once in a while and readjust it. Probably not the best solution.
Dave
   / BX Seat Belt is Killing me, HELP #4
I used to think the seat was uncomfortable on the BX -- but the seat is ok -- it is the tightening seat belt that eventually makes every bump a killer. I've gotten to the point where I undo the seat belt when mowing on rough but flatter terrain. I'm not recommending that approach. I don't like resorting to it -- but my body insists.
Huck
   / BX Seat Belt is Killing me, HELP #5
Well ... I have to admit that the seat belt certainly helps to remind you when it's time to go to the bathroom. It's the old inertia reel kicking in as you hit bumps. Ratcheting down on the lower abdomen ...
My solution (since I know my property well) is to only wear it where I know there are hidden bumps. When I am operating on rough ground I also am driving slowly.
I think that would be the official Kubota line ... try tackling it in 'Turtle' mode!
   / BX Seat Belt is Killing me, HELP #6
I too have definatly noticed the "Bota-constrictor"!
I have just been living with it. I guess a clip is the cheap and easy.
Rogue
   / BX Seat Belt is Killing me, HELP #7
Ya when I am mowing Iam more worrried about the belt cutting me in half than rolling the tractor on my level ground
   / BX Seat Belt is Killing me, HELP #8
I only wear the belt when I might be in a position to roll over. I am just wondering and please do not get angry or anything but perhaps could we stand to loose a bit of weight?--around the middle? /w3tcompact/icons/smile.gif . J
   / BX Seat Belt is Killing me, HELP #9
<font color=blue>but perhaps could we stand to loose a bit of weight?--around the middle? </font color=blue>
Where I come from, we call that ballast! (too poor to afford calcium)
Steve
   / BX Seat Belt is Killing me, HELP #10
Given time, the BX belt will displace the weight in the middle to the top and bottom! ;^)
Are all Kubota seat belts like this? Perhaps one from a different model could be mounted on the BX?
Rogue
NPK H2XA Skidloader Breaker (A50774)
NPK H2XA...
LOT LOCATIONS (A52141)
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
