BX ROPS Engine/Transmission Noise?
   / BX ROPS Engine/Transmission Noise? #1
deathtoblackberries
Battle Ground, WA
Kubota BX2380
So the BX2380 ROPS makes a LOT of noise, engine/transmission noise travels into the ROPS hollow tube, my B2920 did not do this. I read a few posts about this, guys filling with foam or sand. Is this the case on all BX machines or just some?
   / BX ROPS Engine/Transmission Noise? #2
My BX23s ROPS did the same thing. So I just got a can of spray foam an filled the bottom half an that cut the noise way down.
   / BX ROPS Engine/Transmission Noise? #3
I did mine about 4 years ago when I got it...Helped quite a bit...JB.
   / BX ROPS Engine/Transmission Noise? #4
took mine off
Filling the ROPS with foam is my next project, followed by cussing because I need to snake wires through the now foam filled ROPS for the project after that.
   / BX ROPS Engine/Transmission Noise? #6
Run some wire loom, pex or other flexible tubing down the ROPS before doing the foam.
That's a good idea TMGT. Kubota lists LED lights as an available accessory for my tractor for about $200 but I was unable to find a picture or any description I'm checking into this before filling with foam.
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
