BX, removing Freeze plugs
/ BX, removing Freeze plugs #1
Charliebrn
Platinum Member
NW Ohio
Kubota BX-2360
Ok, we all may not want to admit it, but winter's coming. I went out and bought a block heater for my BX2350. I was expecting one that threaded in like my BX2200 did...I even have the tool for it, a 17mm hex wrench. To my surprise, it goes in where a freeze plug is installed by the factory in the engine block.
Anyone done this yet? Can it be done with normal tools? (I don't have a "freeze plug removal tool" if such a thing exists). If anyone knows how, I'm all ears. FYI, it's a 25mm freeze plug.
Also, if anyone's interested, I can take pics and post it as a project if you so desire....
Thanks folks...sure hoping I can get this done in the next few days....
/ BX, removing Freeze plugs #2
I have a BX2230 and the dealer came out to install my block heater and , as I recall, they forgot or lost a specific tool to open up factory plugged hole in the block. The took a large screwdriver and a hammer and punched through it and then pryed it out. To my surprise, the block heater just threaded right in! Don't try that at home!
/ BX, removing Freeze plugs #3
I had a heater installed at the time of purchase (before delivery). I had thought a "block heater" was not available for the 2230 at all, but instead the heater simply heated up the coolant/antifreeze. Is this not correct?
/ BX, removing Freeze plugs #4
Some heat the bock, some heat the water, some heat the oil, some all of the above. You can buy an aftermarket one that sticks on with a magnet.
Watch the wattage use on some of the larger ones, on some pickups it's like leaving your wifes big hairdryer on all night!! :)
/ BX, removing Freeze plugs #5
I installed one in my 2230 last spring. I used the hammer and screwdriver technique. It went without a hitch. You will need a one inch socket to drive it in unless your block is threaded (mine wasn't). My dealer had a had time finding one for me. For others looking for one the part no. is 70000-00771.
The same block heater is available for the BX2230 and BX2350. the instructions specifically mention both tractors. The BX2200 block heater screws into a threaded plug, whereas the 2230 and 2350 gets to be hammered in (carefully, I guess)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
