BX quick hitch lift cylinder reseal.
   / BX quick hitch lift cylinder reseal. #1
Tags
Platinum Member
Connecticut
BX2360/ Kubota SVL90-2/ Kobelco 115SR/ Takeuchi TB260
I have a BX2360 and the quick hitch lift cylinder is leaking. I have purchased the seal kit but was just wondering if anyone else has done this and if there are any tips or suggestions to make it go smoothly, at least smoother than I anticipate!
   / BX quick hitch lift cylinder reseal. #2
What is a 'quick hitch lift cylinder?'
   / BX quick hitch lift cylinder reseal. #3
Could be one of these
That’s what it is.
   / BX quick hitch lift cylinder reseal. #5
I've not seen that hardware before. Very interesting and involving a Kubota with no FEL. That does not look like what would be called a "quick hitch" in terminology I have seen (??)
-- That cylinder looks exactly like an hydraulic top link. Wonder if it can be used for that purpose when not operating the front hitch? Stroke length etc. might be a lot different.
-- Looks awfully easy to get the cylinder off to work on and (if you have experience replacing cylinder seals) it should be very vanilla.
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2020 COLOMBO TM LOT NUMBER 216 (A53084)
2020 COLOMBO TM...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2022 Adams CLC-1013 Conveyor - New (A53472)
2022 Adams...
