bx power
/ bx power #1
cheagle
Eagle Harbor Mi
kubota
I wonder why the bx 25 dose'nt have the bigger engine. the one the 2670 has. Never have too much power I say.
/ bx power #2
It would just spin the wheels faster, or run an implement too large and heavy to handle. It's a little, lightweight tractor.
Bruce
/ bx power #3
Probably because they try to keep the weight down so it's a good lawn tractor?
I wish mine had more hydraulic flow but other than that wouldn't change a thing.
/ bx power
Weight difference cant be that much. Too much power could be it but I go for the power. Spin the wheels faster??? RPMs the same for both engines?
/ bx power #5
I can spin all 4 wheels on my BX23, what more power would be necessary? I've never run out of 'nads on this, traction --yes, power--no.
/ bx power #6
Not sure at what HP emissions comes into play?? Plus I would guess the bigger motor costs more and I have to agree my BX is never having a power problem.
/ bx power #7
I have a 2200 in Pa. and a 1870 in Fl. I just use a few more rpm's in Florida to achieve the same desire. Hard to tell the difference in power.
/ bx power #8
Yeah I have yet to run out of power with BH on and full bucket. Still spin wheels. I can easily lift the rears with FEL. More power for ???
/ bx power
Im not saying the 23hp needs more power but I wonder why the 2670 has the bigger engine. Dosent have a backhoe. I would just think the 25 would need the extra power for the hoe..
/ bx power #10
I somewhat think it is also marketing. People that owned a 25hp Craftsman figure that they need at least another tractor with that much "power."
Little do they know......
/ bx power #11
I see it like marketing cars. Multiple engine choices. Who needs the highest available power... not many.
/ bx power #12
Don't need more than 23HP from a diesel with a backhoe either...If I'm not careful, I could flip my machine with the hoe in a matter of seconds...23HP gas and 23HP diesel aren't even in the same league.
/ bx power #13
What about heavy brush with a brush hog? BTW...can you run a five foot brush hog with a BX...or is a four foot likely the max? Thanks...TomR
/ bx power #14
Never tried it, but 4' would be my guess....Wouldn't even think about that without skid plates though.
/ bx power #16
Not sure what skid plates are...something to support the brush hog as it slides? TMR
Skid plates that protect the HST fan...If you run in the woods or high brush with a BX you are pretty much guaranteeing damage to the fan. Newer models may be protected but older ones were not ...A shortcoming of Kubota for some reason....An MMM can help with the protection to a degree.
/ bx power #17
Ah, the fan protection...I am aware of that. Thanks...I thought maybe the brush hog needed some skid plates to help it along a bit :) TMR
/ bx power #18
My 32hp L3200 is a lot more tractor & is usually traction limited. The much lighter B much less BX doesn't stand a chance of putting that power to the ground. They are what half the weight of my machine (3,500 lbs with ballast & loader)? The limiting factor on the 3pt & PTO is going to be how much it can lift as much as how much it can spin.
/ bx power #19
This reminds me of the BX 25 versus B 2650 debate. I have the BX25, and I run out of traction before I run out of power, but the biggest limitation is in the lifting power of the BX25 FEL. The B2650 does not have much more horsepowe (26 vs. 23 for the BX25), and the PTO horsepower is only 19.5 versus 17 for the BX25, but the real big issue in my view is the frame. The FELis rated for 1200 lbs. or so compared to 745 (which I can never seem to get) on the BX25.
On the other hand, the B2650 with a backhoe on is a heck of a lot more expensive than the BX25.
/ bx power #20
I have always noticed there is a better model out there with more power, higher lift, etc... but for some reason they always want more $$$$ for it :D
1999 GMC C7500 Dump Truck (A61573)
1999 GMC C7500...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
John Deere 302A 50HP Front Loader Utility Tractor (A61572)
John Deere 302A...
