BX mower blade replacement (double check)
   / BX mower blade replacement (double check) #1
buckeyepost
Bronze Member
central Ohio
   / BX mower blade replacement (double check) #2
Get under the deck.... turn the blades so you can measure the Exact clearance between the blades at their Closest... I will bet you have a LOT more than the quarter inch... KennyV
   / BX mower blade replacement (double check) #3
How did you measure the old blade? Should be from corner to corner across. Also if it's been sharpened enough the measurement will decrease.
Someone else just told me that they are measured diagonally, I never knew that... seems kinda stupid really.
   / BX mower blade replacement (double check) #5
You have to think of the blade moving in a circle. The cutting tips will be outside the diameter of the blades measured directly across the blade.
   / BX mower blade replacement (double check) #6
Not really, if you think about how the blade travels then it makes sense as the corner of the blade is going to travel at a larger radius then the center of the squared off end. The diagonal measurement represents the active cutting length of the blade.
I have comercial mowers that have have 2 blade options, one is 2.5in wide, the other is 3in (HD version). In order to maintain the correct cutting width the length straight across the blade must be decreased.
JOHN DEERE S780 LOT IDENTIFIER 225 (A53084)
JOHN DEERE S780...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
New Holland C238 (A50123)
New Holland C238...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
1994 HONDA 300 FOURTRAX ATV (A51247)
1994 HONDA 300...
